Confirmed: Evo ROM Can Be Flashed to Lancer ECU
Old May 10, 2010 | 01:16 PM
  #256
RoadSpike's Avatar
Originally Posted by 03lances
so I guess after I get some race gas and test this out and confirm the knock is still there I will have to flash back my original evo ROM I made to directly replace the lancer rim I was running then adjust the knock multipliers until I am hitting the same knock I was with the lancer ROM in place does this sound right?
Yep thats what I would do.
Old May 11, 2010 | 10:39 AM
  #257
RoadSpike's Avatar
Originally Posted by link62
so a lil update i tried the gta rom again and put my lancer shift pressures and times and other things from my lancer rom and theres still no power to the tranny, when i push on the pedal the engine has to rev to 2-3k just to start to get the car to move foward and i still get massive amount of knock when i go anywhere near boost idk if its cause the knock filters are diff or somthing else but when i get a chance RS ill try to mess with the maps
Link can you try the origional shift pressures and maps in just for a test?
If the car wont shift right I think I'm going to give up on the merging of the rom into this car and work on a different method.
What I'll do is take a look at tephra's large map code and get it into some dead space of your rom. I wont put in the alt maps or anything just the large maps for now.
I'll have to look for that fuel cap and load cap point again but that shouldn't be incredibly difficult.
If we get the maps working correctly we can forget about the GTA rom and just focus on making the lancer auto work right.
Old May 12, 2010 | 04:50 PM
  #258
link62's Avatar
ok so u want me to try the original shift pressures for the gta rom or my lancer rom
Old May 12, 2010 | 05:27 PM
  #259
RoadSpike's Avatar
I meant leave the shift maps alone when you test the gta rom.
I want to see if its going to work at all. It looks kind of bleak at this point to be honest.
I will probably end up modding your rom to use big maps for ignition and fuel which will solve most of the problems :P
Old May 12, 2010 | 05:56 PM
  #260
4g94T's Avatar
I tried the GTA shift pressure and shift time on the Lancer ROM and it does not like it!
Shifts were slooow and it felt like the transmission would fall off
Old May 12, 2010 | 07:23 PM
  #261
RoadSpike's Avatar
I guess I'll be upgrading a rom then to use big maps I plan on leaving the stock fuel and ignition maps where they are and just pointing the main fuel routines to a new spot.
I'll get that fuel limit and load limit patch out in there too shouldn't be too hard just will take me awhile to get it all looking smooth :P
Old May 12, 2010 | 07:59 PM
  #262
RoadSpike's Avatar
Link can you email me a completely stock rom for your car?
I like your car becuase it so closely matches the evo gta rom so I can align everything.
I noticed a few things when i disassembled your rom bro. First off that fuel axis for rpm and load is not right.. I'm not entirely sure what its pointed to but its not right lets just say that.
Injector latency for volts also not right. Probably many others in there to. I'm going to be correcting these in a master XML.
Old May 12, 2010 | 08:16 PM
  #263
link62's Avatar
yea i knew something was wrong with my rom from the begginging cause when i change my load to 10 40 50 and so on it change my injector latancy and when i looked at other ppl roms that did the same their volts didnt change but mine did
you should already have my stock one from the first time i send u my rom unless u want me to send it again if u dont have it
Old May 12, 2010 | 08:27 PM
  #264
RoadSpike's Avatar
If you could send me a bone stock one that would be nice. really I mean the whole 512kb portion
Oh and yeah i did find your battery volts it wasn't that bad
Edit:
Found the load and fuel limits yay
I'll probably implement the table tomorrow i'm kind of tired
Old May 12, 2010 | 09:24 PM
  #265
link62's Avatar
hmmm the only way i can think of getting a stock 512 is for me to input the stock roms data in to my current 512 rom and to flash and re read but other then that i only have a stock rom that i have was the mix of the 15 and 17 that was 256
Old May 12, 2010 | 09:52 PM
  #266
RoadSpike's Avatar
Well it would be nice if you could find the time to do that
A perfectly stock rom would be ideal to use for modding.
Old May 12, 2010 | 11:26 PM
  #267
link62's Avatar
ok so i just pasted everything from my stock rom into the 512 one and gonna send it to you now and i also noticed that my stock rom show its temp is Celsius and the 512 is Fahrenheit
Old May 12, 2010 | 11:46 PM
  #268
RoadSpike's Avatar
Long as all the values are stock it wont matter
I will assemble a better and complete xml for this rom id and then implement the bigger maps from tephra's patch. Should be pretty awesome when its done you'll get a map that's scaled up to 350 load and 8500 rpm.
I'll disable the fuel limiter and load limiters too. We wont need to be hindered by them in this patch lol.
If it all works to plan this can become the ultimate auto rom
Old May 12, 2010 | 11:54 PM
  #269
link62's Avatar
dude your awesome
Old May 13, 2010 | 08:38 AM
  #270
senate6268's Avatar
Scaling up to 8500rpm would be overkill. The piston speeds are pretty high from the 4G94's 95.8mm stroke. Even with a built motor and valvetrain I wouldn't see being able to safely rev over 7500rpm (23.95 m/sec), at most, for very long. 7200rpm (22.99 m/sec) is highest I would recommend for a built 4G94 for longevity. Everyone has their own opinion on maximum safe piston speeds. This is simply mine.
