Confirmed: Evo ROM Can Be Flashed to Lancer ECU
Old May 3, 2010 | 12:03 AM
  #211
RoadSpike's Avatar
Originally Posted by link62
also i just remember do you also want me to change the other ones with these? or leave them stock
We want to modify 00-06 to: (Really 3 variables for 2 bytes of data)
00 = 0x810A
01 = 0x810B
02 = 0x8100
03 = 0x8101
04 = 0x814C
05 = 0x814D
Well i was replacing 02 and 03 with 811c and 811d.
Really i want them all but hey lets just log 3 at a time and move forward
Old May 3, 2010 | 12:07 AM
  #212
link62's Avatar
ok i wanted to make sure cause i did them all u said those were more important so i didnt know if only those need to be changed or not but i got all ready now so ill do some logs in the morning on my way and back from work since its a lil late
Old May 3, 2010 | 12:09 AM
  #213
RoadSpike's Avatar
00 = 0x810A
01 = 0x810B
02 = 0x8100
03 = 0x8101
04 = 0x814C
05 = 0x814D
Which ones did you change? I only wanted the top row, first 6 changed with the ones i listed. I was changing out 02 and 03 with a new variable but we can log that later.
Old May 3, 2010 | 12:11 AM
  #214
link62's Avatar
yea i did replace the first six with what u put with 02 and 03 with the new one, so you want to try the old 2-3 first then the new ones or the new ones first
Old May 3, 2010 | 12:14 AM
  #215
RoadSpike's Avatar
It doesn't matter which come first. If you do the old 3 I'll get a couple more for you to try afterwords
Old May 3, 2010 | 12:16 AM
  #216
link62's Avatar
ok ill do one for each just to get them out of the way and im curious as to whats coming next haha
Old May 3, 2010 | 12:22 AM
  #217
RoadSpike's Avatar
Those three had to do with the old tables so i'm varifying the data. Next I'll focus all my attention on the supposed shift time variables especially 811c which seems to be some sort of primary lookup. Plenty to do
Old May 3, 2010 | 10:24 AM
  #218
03lances's Avatar
Yes its just part of the periphery maps which are the same on any mitsubishi thankfully. Periphery FBA bit 0 should be set to 0 to turn off lean spool.
Lean spool while not evil is horrific to tune with imho. It tends to make the car go richer and richer as you go through the gears. So you could tune a car to be a nice 11.5AFR in gear 3 but have it go to 11.0 in 4th or even richer. I hate the way it leans the map out so I turn it off for direct control.
Once off you map will go very rich but will be consistent in all gears.
Got it thank you!!!
Old May 3, 2010 | 12:57 PM
  #219
link62's Avatar
emailed u the first log of the new 02 03 mut RS
Old May 3, 2010 | 01:51 PM
  #220
RoadSpike's Avatar
Cool just took a quick look.
What mut table values where in there when this was logged?
Couple questions too.
Can you give me like a short overview of the drive like what points you were on the brakes or if the gear lever was moved. Vehicle speed would be good too next time.
Looks like the last mut was really transmission oil temp!
Old May 3, 2010 | 04:31 PM
  #221
link62's Avatar
i used the six u gave me before but with the new 02 and 03, 811c and 811d
and in the begging i was park to reverse to drive and wasnt moved till the end when i parked
and then only time i braked was when u see the tps be at 12 i think
Old May 3, 2010 | 11:18 PM
  #222
RoadSpike's Avatar
Ok lets try a few more.8136
00 = 0x8136
01 = 0x8137
02 = 0x839C
03 = 0x839D
04 = 0x83E0
05 = 0x83E1
Mut 00 has something to do with determining the shift point map so I need to figure it out.
Mut 02 is the currently shift time map
Mut 03 is the current shift pressure map
If possible lets log vehicle speed, what gear its in, etc.
Old May 5, 2010 | 01:04 AM
  #223
link62's Avatar
email sent sorry its in 5 parts my car been having electrical probs recently and evo scan kept disconnecting and reconnecting while i was driving
Old May 5, 2010 | 09:10 AM
  #224
RoadSpike's Avatar
Thats cool man.
There are about 40 maps that seem to control the shifting points of the transmission
It seems to have like scenario's built into them for like when braking, downhill, etc.
Old May 5, 2010 | 10:20 AM
  #225
link62's Avatar
Thats cool man.
wow that be a lot to edit lol so whats next on the list of things to do?
