Confirmed: Evo ROM Can Be Flashed to Lancer ECU
Old May 29, 2010 | 08:04 PM
  #436
RoadSpike's Avatar
Originally Posted by link62
ok so i was able to dip down in to the low 13 and and high 12 so getting there
and i forgot to turn mpd on the first time and when i did i got the code again at start up
Ok disable the mdp code for now must have some error
Something is triggering the countdown timer for the knock light I'll figure it out eventually
Old May 29, 2010 | 08:31 PM
  #437
RoadSpike's Avatar
Ok so there is knock sum increasing when there is knock it just goes away REALLY fast like within 10 ms. The routine is just fast enough to pick it up and transmitting it to you.
I suggest going into knock control and either adjusting one of two things.
1) we can ignore knock below a certain load say 110 load?
2) we could add 1 to the knock multiplier and see if its enough to decrease these instances
The only other solution is to put some kind of predelay into the routine to wait like 15ms of knock before taking action
Old May 29, 2010 | 08:45 PM
  #438
link62's Avatar
hmmm i guess well do what ever you think might work better haha
Old May 29, 2010 | 09:07 PM
  #439
RoadSpike's Avatar
Or you could just adjust the timing :P
I would do the load ignore before the multiplier myself
Old May 29, 2010 | 11:21 PM
  #440
RoadSpike's Avatar
You know this may be stable enough to send out patches to people let me know who's interested. Please at this time only experienced modders
Old May 29, 2010 | 11:30 PM
  #441
link62's Avatar
sweet one question where 4g94t at he just disappeared
also i saw that u set the map test 1 at 0 is that right ?
Old May 29, 2010 | 11:34 PM
  #442
RoadSpike's Avatar
Yeah they are fault tolerance values I probably should make the last one 0 too as it also can be messed with by the map averaging code
Old May 29, 2010 | 11:36 PM
  #443
link62's Avatar
ok so change test 3 from 1.80 to 0
Old May 29, 2010 | 11:37 PM
  #444
RoadSpike's Avatar
or 0.10 which is low enough
Old May 29, 2010 | 11:49 PM
  #445
link62's Avatar
cool got it now just need to flash it to the car and get a log, anything u want me to log for muts/evoscan
Old May 29, 2010 | 11:51 PM
  #446
RoadSpike's Avatar
not really at this point.
If anything remove some stuff so it logs faster
Sometime we may want to try the rear 02 sim see if it throws a code :P
Old May 29, 2010 | 11:53 PM
  #447
link62's Avatar
i was wondering if we were gonna give that a go also what about airflow calcs cause i always see those two on by default when i get the roms from you
Old May 29, 2010 | 11:58 PM
  #448
RoadSpike's Avatar
Sure if you want its not set in the mut now so
Mut00 = 8D50
mut01 = 8D51
Old May 30, 2010 | 12:03 AM
  #449
RoadSpike's Avatar
Mut00 = 8D50
mut01 = 8D51
Hey link I noticed when i sent you the 1byte load thing i put in 1.3 as the scaling factor but in the rom its only 1.2.
either fix the scaling factor in evoscan or probably more easily fix the scaling factor in the rom to 1.3 instead of 1.2 so it matches
  #450
link62's Avatar
Mut00 = 8D50
mut01 = 8D51
ok ill give it a shot in the morning and see what happens
