Confirmed: Evo ROM Can Be Flashed to Lancer ECU
Old Jun 4, 2010 | 10:39 AM
  #481
RoadSpike's Avatar
Link I sent you an email with a couple values to log if you please
We will see if the cranking enrichment values are messed up
Old Jun 4, 2010 | 07:57 PM
  #482
bvasquez12's Avatar
Okay i did the flash of the evo rom onto my lancer ecu, swapped my pins back around, and im using a rom that was made by a guy on the 3g forum. its similar to the stock 4g64 rom but a little richer. I took a few logs and i got as high as 17 knocks at 4100 or so rpm. I dont have a wideband yet, ill order one next weeked, but should i go ahead and retard the timing a bit, or could it make me run too lean?
Old Jun 4, 2010 | 11:01 PM
  #483
link62's Avatar
yea i got it ill get you a log in the morning since its my day off
Old Jun 4, 2010 | 11:53 PM
  #484
03lances's Avatar
It will not make you run lean, definately lower that timing bro before you break something!!!
Old Jun 5, 2010 | 07:55 PM
  #485
bvasquez12's Avatar
okay i copied the eclipse fuel and igntion tables over and got it to a steady 0 count of knock. without a wideband, would it be okay to just use the lancer rom and copy all the eclipse settings over, and drive it like so.
maybe it would be easier to do it this way, so there wont be any unfilled values due to the larger tables and maps the evo rom has compared to the eclipse rom.
If anyone has a lancer rom, can you email it to matayde12325@hotmail.com
Old Jun 5, 2010 | 08:30 PM
  #486
bvasquez12's Avatar
also i noticed the "open loop load 1 and 2" are different from the evo rom and eclipse rom, also the "open loop throttle high and low load" are different, should i copy these over also?
Old Jun 5, 2010 | 09:30 PM
  #487
senate6268's Avatar
Yes. You will be better off running a Lancer ROM and copy all the tables from the Eclipse ROM in so you don't have to deal with the Eclipse's immobilizer.
Old Jun 5, 2010 | 10:43 PM
  #488
link62's Avatar
email sent
Old Jun 5, 2010 | 11:12 PM
  #489
bvasquez12's Avatar
Can someone send me a lancer rom.so should I change the other settings I mentioned on the evo rom
Old Jun 5, 2010 | 11:46 PM
  #490
03lances's Avatar
Just sent you my bone stock lancer rom bvasquez12 hope it helps
Old Jun 5, 2010 | 11:54 PM
  #491
bvasquez12's Avatar
Thanks bro i'm gonna try it out tomorrow :-o
Old Jun 6, 2010 | 06:07 PM
  #492
bvasquez12's Avatar
so i used the lancer rom, ALL the settings i could, over to the lancer rom, and it runs okay. The idles is alot smoother, i had to plug in the egr solenoid but now i have NO CEL's yet. I wonder if that darn o2 sensor code will come back. So now i just need a wideband, so i can tune out the AFR right?
Also what box do i need to check in order to log my load, is it 1byteload on the lancer rom or is it ecuLoad?
Old Jun 6, 2010 | 06:37 PM
  #493
RoadSpike's Avatar
1byte load is only for tephra mods use ecuload as its unlikely you'll go over 160 load points without turbo
Old Jun 6, 2010 | 06:38 PM
  #494
RoadSpike's Avatar
Originally Posted by link62
email sent
Startup appears to be behaving normally thanks link
Old Jun 6, 2010 | 07:22 PM
  #495
link62's Avatar
hmm ok well im not sure what to do now to get the start ups better cause im not sure if the changes to the enrichment did anything cause i still got to push on the pedal to start it
