CBRD new BBKB results
Old May 13, 2011 | 08:38 PM
  #556
wally7714's Avatar
Well I didn`t enjoy mine for too long. My brand new BBK-B died (shaft was bent) after few hundred miles. Blouch didn`t warranty the turbo cause they said I didn`t use the right oil ( which was Castrol Full Synthetic) and the Cover was chromed out. What a disappointment. I bought BBK cause it was suppose to be such a reliable great turbos for a pump gas and here I am almost 2 grand down the drain.
I hope you guys have more luck than me but I know one thing , no more BBK`s for me.
Old May 13, 2011 | 08:50 PM
  #557
CBRD's Avatar
Used turbo... Cover removed... Chrome in the inlet to the compressor... Clean up done in the compressor outlet... Coating dine to the turbine housing.... Customer didn't receive the paperwork about startup etc....
Cb
Old May 13, 2011 | 08:51 PM
  #558
MJ23FE's Avatar
Did you get the warranty paperwork/instructions and use the specified oil???
-Jalal
Old May 13, 2011 | 08:53 PM
  #559
MJ23FE's Avatar
Lol nvm. Chad answered my questions! Hah.
Def no bueno and are issues that would def contribute to the failure of a turbo. With so many hands touching that thing having it checked out before install is a good idea. granted you bough it coated...
-Jalal
Old May 13, 2011 | 09:12 PM
  #560
sparky's Avatar
Originally Posted by CBRD
Used turbo... Cover removed... Chrome in the inlet to the compressor... Clean up done in the compressor outlet... Coating dine to the turbine housing.... Customer didn't receive the paperwork about startup etc....Cb
You can't remove a cover on these Blouch turbos? I guess that there are always excuses. It was a Blouch turbo and it failed...duh! Certain oils. No coatings. If they are previously owned then they are no good. Come on! This is wimpy sh***t. Another motherless child.
Old May 13, 2011 | 09:15 PM
  #561
sparky's Avatar
OP said the shaft on his brand new BBK-B was bent. That's not Blouch's fault. It's buyer's fault. Pass the buck, wow! Blouch is gonna get it right sooner or later.
Old May 13, 2011 | 09:20 PM
  #562
sparky's Avatar
Coating the housing bends the shaft....yeah, right. Maybe Blouch didn't check shaft runout? Oh, that's not possible.
Old May 13, 2011 | 09:23 PM
  #563
sparky's Avatar
There is a reason why Blouch doesn't even post on this forum. He is not responsible for his own mistakes.
Old May 13, 2011 | 09:35 PM
  #564
black & yellow's Avatar
the turbo had zero miles when it was put on wallys car it was good oil and the bearings were tight not loose when removed the turbine shaft was just bent ??? seems like crappy parts FP ALL THE WAY <3 NOT EVERYONE CAN HAVE THE BEST LOL
Old May 13, 2011 | 09:39 PM
  #565
the part i dont understand is fine take the compressor housing off and chrome the ***** so what that has nothing to do with the balancing of the turbine ?? believe what u want if wally ever gets his turbo back from chad i will personally take it apart and take all the pictures u want sounds scetchy if u ask me if he paid to ship the turbo to cbrd y doesnt he get it back confusing
Old May 13, 2011 | 09:53 PM
  #566
CBRD's Avatar
He is getting the turbo back there was sanding done to remove chaining from the inside of the compressor housing... He didn't get paperwork regarding priming of the turbo... Etc.
Cheers
Cb
Old May 13, 2011 | 10:02 PM
  #567
hay its not my money i was just puking up info what ever makes u sleep at night mr chad i am just a garage rat or grease monkey no no def rat so much cooler
Old May 13, 2011 | 10:09 PM
  #568
i do understand that the compressor housing was chromed out i also understand it had to be taken off i understand there was chroming inside the compressor bla bla bla i get all that i put it on lol all im saying is i just dont understand what that has to do with it the bushings for the turbine shaft or bearings whatever u wanna call it seemd just as tight as when i put it in so i dont see it being lube its like it just bent like it was out of balance i am not saying cbrd sucks im not saying that at all because u proved that lots of people have good luck with the stuff it was more just a curiosity thing is all if the bearings arnt loose and the shaft is bent how does it happen it is quite interesting if u ask me but like i said just a garage rat what do i know
Old May 14, 2011 | 01:04 AM
  #569
golgo13's Avatar
EvoM Community Team
Veteran: Navy
/popcorn
I'm sure this will get sorted out in the end.
I don't usually read too many threads about issues with CBRD WC or their customer service.
Old May 14, 2011 | 04:38 AM
  #570
CBRD's Avatar
A housing that is sliding over a turbine or compressor with a hair thickness of clearance.... Imagine what can happen if it's slide on at an angle.
The situation is unfortunate... We have offered the owner a reduced price on a bbk or bbkb (even though he wasn't original owner)
Cb
