Jacking Points with a Floor Jack
Old Nov 1, 2008 | 03:55 PM
  #91
Stealthmatt's Avatar
dangerous much - im just going to stick to factory recommend locations - as id think they would know what they are talking about...
Old Nov 22, 2008 | 11:17 PM
  #92
funks's Avatar
Is the front jack point actually the towhook, or the square protrusion on the front cross member just behind the front towhook?
Old Nov 24, 2008 | 08:26 PM
  #93
IMPdemon's Avatar
The protrusion, although I've used points all along that member. I just wouldn't use the tow hook.
Old Aug 14, 2011 | 05:46 AM
  #94
jr_2006IXMR's Avatar
is that right???
Old Aug 14, 2011 | 08:25 AM
  #95
IMPdemon's Avatar
Is what right?
The diagram in this post earlier should clear things up.
Old Aug 18, 2011 | 08:41 AM
  #96
The protrusion by the tow hook. Im going to try it out. If I don't post again i miss u guys.
Old Aug 18, 2011 | 09:03 AM
  #97
deeman101's Avatar
I've had my share of troubles jacking up my car. Pinch rails are fubared around the driver's door area, subframe rails crushed at a few places, etc. I had to bang the rear floorboards back with a sledge hammer because I thought those subframe rails could hold the weight of the car.
Also the crossmember it self is NOT a good jack point. That little square pad is a good jack point. If you jack from further back from the jackpoint on the crossmember you will see the crossmember actually bend before the car lifts off the ground. I only noticed it because I'd hear the bolt holding subframe brace to it clunk around, and one day I saw it bend as I was jacking it up.
Also those 2 little skids at the end of the subframe rails in the rear (about in line with the rear passengers heel I believe) looks very tempting as a jacking point. But those have bent too when I left my car on jackstands overnight. The forward part tilts up as the rear floorboard gives way.
Now I only use rear diff, front jack point (when my undertray is not on), and pinch rails very carefully. I always jack with a hockey puck, never metal on metal (that bends pinch rails).
Btw I've had all these troubles because my car is so low and I try to jack my car as far off the ground as possible to make it easier to work under.
Old Aug 18, 2011 | 11:56 AM
  #98
Well I finished with the oil change and used the small square area behind the tow hook at the front and there was no bending and felt pretty safe with the stands as well. I'll keep using this method. Thanks guys.
Old Nov 15, 2011 | 09:14 PM
  #99
EnjoyDriving's Avatar
Sorry for bringing up this dead thread - but I've seen the pics and graphs for the "jacking" points, but how about the "best spots" to set the jack stands against on?? I am currently having my car driven up on a pair of Rhino ramps for the winter storage/project. But then I noticed that the tires inner wall are being pressed a little bit, and I'm worried that they will cause flatspot or deformation to my tires after 4-5 months of storage - therefore, i'm planning to jack up the front car a little bit and set it on a pair of floor stands instead - but I've never done this and would like to find the best spots for the stands!!
Like some requests made before, if ppl can provide a pic or graph to show the best spots for stands, it'd be wonderful!! If not, a detailed description can still be very helpful!!
Old Nov 17, 2011 | 07:28 AM
  #100
IMPdemon's Avatar
https://www.evolutionm.net/forums/3909234-post57.html
Old Nov 26, 2011 | 06:29 AM
  #101
ILuvJDM's Avatar
so was this a proper jack-stand placement? It was on that double metal piece that runs down the length of the sideskirts (I used to put them here on my Honda as well)
The car was very stable and was up there almost all day
Old Nov 27, 2011 | 12:10 PM
  #102
groundzero1v's Avatar
looks like it.. but we can't really see where exactly you placed the jackstands... what did u do btw?
Old Nov 27, 2011 | 12:16 PM
  #103
chrisw's Avatar
go here
https://www.evolutionm.net/forums/9532702-post95.html
Valerie Strong
Mitsubishi TC-SST Discussion
13
Mar 4, 2017 01:21 PM
EVSEVO8
Jacks Transmissions
Feb 3, 2017 12:16 AM
Rom
Dec 17, 2015 01:09 PM
CottageLifer
Outlander Sport
May 14, 2015 01:15 PM
Dbar4G63IX
Aug 18, 2010 03:12 AM
