MAP EF-series Turbochargers results thread
Old Aug 23, 2011 | 06:23 PM
  #61
EVO(boss)'s Avatar
Originally Posted by getsideways
First off i wanted to start a thread and keep all dyno charts of the EF series of turbochargers on the first page (i will save space) , Please submit yours along with your list of mods and i will glady add it ..
By all means make your own thread but It'd be great to have all the charts in one place.Its much easier to search for results this way and keeps the clutter down in the dyno section.
Thanks to the moderators who keep it clean , I hope the members here add enough useful data to warrant a sticky here eventually!
Thank-you Chris Carey and all the members of MAP for working hard on great products that perform. Im very happy with my latest addition to the already hardworking MAP parts on my car.
And on to the results.........
2006 EVO9 RS -------- EF3--------93 octane Stock Block\Head
Injen Intake
Custom LICP
ETS 4'' Intercooler
Injen UICP
Synapse DV
Stock TB,Intake manifold,Head,Bottom end
FIC 850cc injectors
GSC S1 Cams
MAP ported\coated exhaust manifold
MAP EF3 ported\coated NON-antisurge cover
Map Divorced recirculated Downpipe (02 delete)
Cobb titanium Catless exhaust
Hallman MBC
93 octane fuel
Tunes shown are at 3 different boost levels, Boost is dropping 2~ PSI from peak on shown runs (28 falling to 26)
AFRs are falling to 11.3~ at redline.
Timing is kept conservative around High load spool up to allow torque to come on easily , My car sees regular High speed track events and to keep the stock block happy this is neccesary.
The 30 PSI pull was started late thus the Later spool, Also it knocked up top and i backed out , if you look at the graph carefully you can see where the computer pulled 2 degrees of timing near redline, Im sure with refining i can eliminate that , but i will never run 30 PSI on 93 Unless its just to run down the strip.
I just wanted everyone to be aware that it has a LOT left in it.
great job man ,, which wheels are those on the white evo on the track ??
Old Aug 23, 2011 | 06:24 PM
  #62
EVO(boss)'s Avatar
sorry
Old Aug 23, 2011 | 07:27 PM
  #63
PlanoEvo's Avatar
Mods Map stage 2 2.3 10.5:1 CR Map Stage 3 Head ported everything.
Made 478whp and 425wtq Boost was 28.4 at peak tapering to 23 up top
Self tune be kind I'm still learning E85
Old Aug 23, 2011 | 08:49 PM
  #64
getsideways's Avatar
Wheels are Rota P45R Super heavy but very good looking one of my favorite wheels on an evo.
Holy nice spool Planoevo , You surpass 200whp at 3300 RPM . Is there anyway to get it to make more boost ? I think the Fuel and motor can take it , Actuator opening ? Also what method of boost control?
Thats pretty much the powerband im shooting for next year! 450 TRQ and 500 WHP is what im looking for im sure your car has that and more in it.
Added your results to page 1
Old Aug 23, 2011 | 10:00 PM
  #65
PlanoEvo's Avatar
Forgot to mention it was 102F in the dyno room when I put down those numbers! Also a Mustang Dyno
Old Aug 24, 2011 | 05:41 AM
  #66
Kracka's Avatar
PlanoEvo's charts:
Old Aug 25, 2011 | 04:18 PM
  #67
pkron05's Avatar
Any results for EF2? Mine should be up in a few days.
Old Aug 25, 2011 | 04:49 PM
  #68
You would be the first ive seen on evom , I saw a chart in the teaser video for the EF2 but no one has done their own yet.
Old Aug 25, 2011 | 04:55 PM
  #69
pkron05's Avatar
Ok. I asked because it said saved for EF2 on the first page. Graphs should be up on Monday-ish. I don't have many details until I pick up the car and see the graphs, but the best pull was 387 hp @ 28 psi. I'm kinda disappointed.
Old Aug 25, 2011 | 05:00 PM
  #70
That sounds dissapointing , make sure you ask where the bottleneck is if you dont already know, im guessing you were on 93 , and where you using a HP actuator?
Old Aug 25, 2011 | 05:13 PM
  #71
pkron05's Avatar
That's the thing, it's on E85. It has the MAP 22 psi actuator IIRC, if that answers your question. We're going to have to evaluate the car some more and spend more time tuning. The car was knocking alot at 30 psi and fine at 28, so that's were it's staying for now.
Old Aug 25, 2011 | 05:16 PM
  #72
CurseDSM's Avatar
That ef2 should make more power then that at 28 psi. For what I am experienceing with my ef4 I will almost garentee it will make much more power then that.
Old Aug 25, 2011 | 08:24 PM
  #73
Low reading dyno? ha I dunno sounds like you need to take a close look over everything , who tuned it?
Old Aug 26, 2011 | 08:27 AM
  #74
ChrisCarey's Avatar
There is definitely an issue somewhere in the configuration, see the below results at 27psi.
Modifications:
MAP EF2 Turbocharger
FIC 1150cc on E85
Hallman MBC
ETS 3" FMIC
MAP LICP
Megan Racing TBE
BC272 Cams
Old Aug 26, 2011 | 12:41 PM
  #75
Levar's Avatar
Veteran: Army
Modifications:
FIC 1150cc on E85
Hallman MBC
ETS 3" FMIC
MAP LICP
Megan Racing TBE
BC272 Cams
That EF2 is no joke in its own right. 420wtq nearly flat across should bring a smile on the face of the daily driver at heart.
