Patch: Force OBD Inspection Pass (acamus, mrfred)
Old Sep 15, 2011 | 08:53 AM
  #226
killerpenguin21's Avatar
Originally Posted by Evo H8
Here is a screenshot
$50 bucks over paypal to the first person who can help me and I'll also donate $25 to the thread cause!
well i cant be as much help as i thought. i screwed my settings at some point it seems and the shop didnt give a full print out. i THINK that these are the settings i passed with combined with the rear o2 patch. secondary o2 and a/c should definitely be off. im unsure about the evap and heated catalyst. but my thoughts on it are that your readiness monitors (monitor available) should match a stock rom, then you adjust the pass/fail setting based on what you need to force pass ie removing egr. but these are my settings compared to a stock 0015 rom.
you could always try these, go get inspected and if you fail, that should clue you into what the perfect settings should be.
Old Sep 15, 2011 | 05:26 PM
  #227
septagent's Avatar
is this it?
When i plug it in to my computer (i started with the same rom as you, later moved on to tephra mod): this is what came up for the settings:
Based on that, it doesn't look like any of the patching has been applied.
you need to make sure that the following steps are followed:
Non-Continuous Monitor Completion Patch
@36796 DA2A -> EAFF
@36798 6AA1 -> 6AA7
Non-Continuous Monitor Availability Patch Part 1
from 4019 to E000
Non-Continuous Monitor Availability Patch Part 2
from 6AA1 to EAFF
If you can fix those, then hopefully your availability chart will show accurately and you will be changing the settings you think you are changing.
This is a question directed at the others on the forum:
Would the fact that i've moved on to tephra v7 affect the regular ROM and how it appears when i bring his ROM up in my ECUFlash? Am i seeing what i think i'm seeing, or does all the hex values not match up because of what i did to upgrade to tephra (and an altogether different ROM).
You'll have to forgive me, because i haven't done this in well over a year and don't have the time to brush up on all the upgrades i did before trying to help evoh8 out.
The real question: If i update the rom from my machine and send it back to him, is there risk of it messing something up? I wouldn't think so, since i regularly switched between ROMs on my Evo (back and forth from tephra to regular) when i originally did the upgrade.
Attached Thumbnails Patch: Force OBD Inspection Pass (acamus, mrfred)-evoh8.jpg
Old Sep 15, 2011 | 06:41 PM
  #228
Evo H8's Avatar
Septagent -
You are right, I installed the patch on my new laptop today and noticed the same thing. I changed it now. I'll reflash it and take it in for inspection next week. I'll let you know if it worked.
Question to all, for Monitor avail/not Avail and Monitor passed/Not Passed should they both be the same and go as follows? :
EGR System 1
Oxygen Heater Sensor 1
Oxygen Sensor 1
A/C System Refrigerant 0
Secondary Air System 0
Evaporative System 1
Heated Catalyst 0
Catalyst 1
ROM# 94170008 2003 Evo 8
I have a Tactrix Openport 2.0 - is there any special patches or anything I need to do that could prevent me from flashing my ECU?
Another question - is there a way for evoscan to be able to tell if these are ready/not ready without having to go to a service shop?
Thanks
Old Sep 15, 2011 | 06:55 PM
  #229
Evo H8's Avatar
Originally Posted by 4kinboost
"Secondary Air system - should be not supported
A/C refrigerant - should be not supported
Heated catalyst - should be not supported"
What blobits did you adjust?
When I change these to not available it changes the hex codes for my Non-Continuous Monitor Availability Patch #2 from the recommended E000 to EAE5. Is this going to pass inspection?
Old Sep 16, 2011 | 04:23 AM
  #230
l2r99gst's Avatar
Septagent -
EGR System 1
Oxygen Sensor 1
Heated Catalyst 0
Catalyst 1
Thanks
Looks about right.
I haven't used EvoScan recently, but you can use Scantech (free software) to check the readiness monitors. That way you will know for sure if you will pass inspection before you go.
Old Sep 16, 2011 | 08:32 AM
  #231
when you set all the hex and such listed in the how to, you get the values that i showed in the top line of my picture. the hex values should change when you change the 1's and 0's.
do you have a copy of scantech? i tried to find it the other night, but it seemed every link was broken.
Old Sep 17, 2011 | 11:48 AM
  #232
Evo H8's Avatar
Can someone tell me how to check the readiness monitors using evoscan? I cant get scantech to recognize its plugged into my car.
Old Sep 17, 2011 | 04:00 PM
  #233
RazorLab's Avatar
You can't. Use PCMscan
Old Sep 18, 2011 | 12:00 AM
  #234
TurboTim06's Avatar
PCMScan FTW!
Old Sep 18, 2011 | 09:55 AM
  #235
Evo H8's Avatar
Here is a mirror link: http://evoecu.logic.net/mirror/svn/tools/ScanTech/
Old Sep 18, 2011 | 10:40 AM
  #236
thanks, the wiki was down when i looked the other night
Old Sep 18, 2011 | 12:48 PM
  #237
logic's Avatar
Yeah, small speedbump in moving the wiki to a new server and OS version. Things should be back to normal at this point.
Old Oct 19, 2011 | 09:04 AM
  #238
motorspt's Avatar
Great work
Old Oct 22, 2011 | 07:03 PM
  #239
DJAfterShok's Avatar
Has anyone tried this for illinois emmisions? I'm due to go next year and this would deff be helpfull! All i have to do is slap a cat!
Old Nov 7, 2011 | 02:55 PM
  #240
Evo H8's Avatar
I did the mod myself and it worked!
I just donated $25 to Tephra. Everyone else who uses this mod successfully should do the same!
Killerpenquin21 - PM me your paypal address. I owe you $50 for your help.
