MAP EF-series Turbochargers results thread
Old Dec 9, 2011 | 07:00 PM
  #421
ivan22's Avatar
Originally Posted by getsideways
You wont need the antisurge housing as long as you have a decent BOV you wont have issues.
will it affect performance if u don't have issues and have the anti surge i ordered it just in case i mean isn't it better to have it just in case then have issues later and not have it
Old Dec 10, 2011 | 06:57 AM
  #422
getsideways's Avatar
Early on MAP claimed the antisurge housing lost a decent amount of spool on the EF3, That was before even the Beta release. So i guess i dont have a real answer for you since they have been and are still tweaking everything they can to make these perform at an even higher level!
I dont wanna misslead anyone in case it has changed someone from MAP will have to chime in.
Old Dec 12, 2011 | 08:29 AM
  #423
ChrisCarey's Avatar
We did see some spool lost going with the anti-surge cover on the EF3, however if you go with the standard cover and don't keep surge in check longevity of your turbocharger will suffer.
Old Dec 15, 2011 | 09:19 AM
  #424
Kracka's Avatar
Here's my old Evo IX!
Cobb - Plano tuned (Accessport) on E80
MAP 2.3L Stage 2 block
MAP ported head
MAP EF3 turbo w/anti-surge cover
Kelford 272 cams
MAP Rev3 intake manifold
Mil.Spec 65mm ported throttle body
Perrin intake
Perrin FMIC
Buschur ported exhaust manifold
Buschur o2 housing
Buschur turboback exhaust
bunch of other stuff...
Old Dec 15, 2011 | 09:45 AM
  #425
Levar's Avatar
Veteran: Army
MAP ported head
Kelford 272 cams
Perrin intake
Perrin FMIC
Buschur o2 housing
Did you just repost this to show off, my friend? Just kidding. For those that do not believe, this is proof what a good group of parts can do for a set up. 500whp and 450wtq on E85 @ 27PSI is great (but you knew that already). I hope that I can achieve roughly 475whp and 425wtq with my MAP 2.1L engine when it is all said and done.
Old Dec 15, 2011 | 09:58 AM
  #426
Kracka's Avatar
Repost? This just happened yesterday.
Old Dec 15, 2011 | 10:02 AM
  #427
Levar's Avatar
Veteran: Army
This was at the top of your post and it threw me off. No biggie, my friend.
Old Dec 15, 2011 | 10:04 AM
  #428
ChrisCarey's Avatar
It's owned by another gentlemen now
Old Dec 15, 2011 | 10:16 AM
  #429
Kracka's Avatar
Yup, sorry for the confusion, I sold the car to a local guy about a year and a half ago, but have kept in contact with him. He isn't a member here so I figured I'd post it for him
Old Dec 15, 2011 | 11:27 AM
  #430
Levar's Avatar
Veteran: Army
No issues, my friend. It is all good.
Old Dec 16, 2011 | 08:42 AM
  #431
Kracka's Avatar
http://www.youtube.com/watch?v=Snaejg_Ry5Q
Old Dec 16, 2011 | 09:17 AM
  #432
Disco Disco
Added
Old Dec 16, 2011 | 11:08 AM
  #433
Levar's Avatar
Veteran: Army
I believe that I will be the only one here running the EF3 on the stock block and pump/91 as a short-term set up. I just want to take things easy and preserve the bottom end until I can get it built.
Old Dec 16, 2011 | 11:33 AM
  #434
ivan22's Avatar
^Ur not the only one I'm gonna runn my on e85 and 91 for winter stock block but it is getting tuned on e85 first since that's what's in my thank now and then 91 later just if I get stuck without e85 (duel map switching)
Old Dec 16, 2011 | 11:36 AM
  #435
mrfred's Avatar
MAP ported head
Kelford 272 cams
Perrin intake
Perrin FMIC
Buschur o2 housing
What gear for those dyno runs?
