MAP EF-series Turbochargers results thread
Old Nov 21, 2011 | 09:00 PM
  #376
getsideways's Avatar
Get you some! Very nice 550 on pump whew!
Old Nov 21, 2011 | 10:07 PM
  #377
Steveevo9's Avatar
Originally Posted by wanguru
Switched to TephraMod v7 + GrimSpeed and cranked the boost up to about 29-5lbs just for giggles. Still running BP 93 pump but the ID1000s are barely keeping up (109% DC up top at 45psi base pressure). But the EF4 definitely comes alive around 29lbs and still has plenty more to go.
Updated Engine Mods:
Fully built 2.3 stroker (9:1CR)
MAP EF4 with FP 25psi Actuator
MAP Rev3 intake
MAP ported exhaust manifold
MAP MVS DP with Ext WG
MIL.SPEC 65mm TB
AMS CNC head
AMS FMIC
AMS fuel rail/ID1000s/single 255 walbro
Short route IC piping
Kelford 272s
Power Enterprise TB
Spoolin up COPs
GrimSpeed 3-port
TephraMod v7 (still on MAF)
Another well planned & executed build, really impressive parts combo with VD results cementing it all. Congratulations mate .
Old Nov 22, 2011 | 10:39 AM
  #378
EnjoyDriving's Avatar
Originally Posted by cursedsm
There is always black friday if Chris puts them up...
any update on this, Chris I'm interested in the EF3 and am wondering if I can upgrade my IX turbo to it?
Old Nov 22, 2011 | 11:29 AM
  #379
Kracka's Avatar
Yes, PlanoEvo sent in his stock turbo and had it upgraded into an EF3. MAP offers both new turbochargers and rebuild options. This has been covered many times
Old Nov 22, 2011 | 11:38 AM
  #380
ChrisCarey's Avatar
See the upgrades tab on the left side of this page
http://turbos.maperformance.com/evo-turbos.html
Old Nov 22, 2011 | 11:51 AM
  #381
Sirnixalot's Avatar
All your Evo X EF series info pages have "10.5" turbine housings.
Shouldn't they be 12cm^2? Just making sure
Also the SRT4 EF3 says:
This is a serious turbo that sees 20+psi by 4000-42000rpm
Old Nov 22, 2011 | 12:15 PM
  #382
murlo26's Avatar
Proofreader chiming in lol
Old Nov 22, 2011 | 01:22 PM
  #383
ChrisCarey's Avatar
Haha good catches!
Old Nov 22, 2011 | 02:23 PM
  #384
Someone from the caymans just schooled your proofreading department
Go EF3 you wont look back!
Old Nov 22, 2011 | 02:26 PM
  #385
ChrisCarey's Avatar
Hey now I haven't heard anything out of you two either! lol
Old Nov 22, 2011 | 02:32 PM
  #386
CurseDSM's Avatar
Maybe there out enjoying the last few good days they have with ef turbos on there car............
Old Nov 22, 2011 | 03:24 PM
  #387
Yea we need to talk ill send you an email soonish maybe after all this black friday BS
Old Nov 22, 2011 | 05:45 PM
  #388
Does the EF2 use the same compressor/turbine wheels as the EF3 does?
If so, the main differences between EF2 and EF3 are the upgraded thrust components and oil line kits in EF3, right?
Old Nov 22, 2011 | 05:55 PM
  #389
Kracka's Avatar
The EF2 and EF3 share no wheels.
EF1: stock turbine, EF2 compressor
EF2: EF2 turbine, EF2 compressor
EF3: EF3 turbine, EF3 compressor, 3" anti-surge cover optional, oil line standard
EF4: EF3 turbine, EF4 compressor, 3" anti-surge cover standard, oil line standard
Old Nov 22, 2011 | 06:04 PM
  #390
Thank You for theinfo. So the EF3 and EF2 use different compressor and turbine, right.
