MAP EF-series Turbochargers results thread
Old Nov 16, 2011 | 08:18 AM
  #331
ChrisCarey's Avatar
Originally Posted by cursedsm
Well I can answer this and I am sure some others can too. I have an ef4 with stock block and head with upgraded valvetrain with cams I am making over 500 whp. Hope that answers the question asked.
The EF4 would be my recommendation, I just can't comment on spool for the Evo X EF4 on a 2.0l as of yet
Old Nov 16, 2011 | 08:32 AM
  #332
Kracka's Avatar
500whp is quite the goal on pump gas and in my opinion is a little too lofty for a stock block setup... If you're dead set on it though, you will need the EF4 since the EF3 or Red won't be able to do it.
What really strikes me as odd is your desire to keep stock-like spool and response. You really need to pick your priorities here and decide what your realistic goals should be. If it's stock spool/response you want then grab the EF2 and aim for 400whp on pump. If you're willing to sacrifice ~500 RPM spool with WHP in the range of 450 then the EF3 is the proper choice, but if you're set on 500whp then get the EF4, be willing to deal with lag, and plan on a full list of all the bolt-ons you can think of plus a savings account with enough money to cover a built engine.
Old Nov 16, 2011 | 09:51 AM
  #333
Jrah2987's Avatar
Veteran: Air Force
Chris,
For what it's worth, if you put the EF4 on sale for Black Friday, I will definitely buy it. Will go nicely with the 2.4 block I bought from you. I've never had the slightest problem with anything I buy from you guys.
Old Nov 16, 2011 | 12:20 PM
  #334
Semih321's Avatar
I would be fine with 450 to 480 whp.....let me list my current mods
UR Exhaust
UR Test Pipe
Injen UICP + 3' Intake
COBB AP - running stage 2 map
ETS 3.5' IC - coming soon
UR downpipe open O2 dump - ordered
Looking to get this turbo on with a set of injectors and fuel pump and drive....in 2 or 3 months go GSC S2 cams w/ springs and retainers and APR headstuds.
So basically I want to know if I put the ef3 on with full bolt ons...am I safe on stock motor....assume I redline the car at least once a day....for arguments saek
By the way does anyone know how the spool of ef3 compares to fp red?
Old Nov 16, 2011 | 12:31 PM
  #335
ChrisCarey's Avatar
I'm running ~465whp with an EF3 at the moment (albeit on E70) but in regards to the well being of your bottom end I think you'll be just fine.
Old Nov 16, 2011 | 12:53 PM
  #336
Semih321's Avatar
Ef3
Car would be running on 93 pump stock head/block.
Old Nov 16, 2011 | 12:55 PM
  #337
ChrisCarey's Avatar
I know, I'm just saying the power level should be fine.
Old Nov 16, 2011 | 01:48 PM
  #338
Semih321's Avatar
Are you on stock motor? What kind of fuel system you running?
Old Nov 16, 2011 | 02:00 PM
  #339
ChrisCarey's Avatar
Yes I am, Walbro 400lph pump, FIC 1100 injectors, and MAP AFPR kit.
Old Nov 16, 2011 | 03:08 PM
  #340
EnjoyDriving's Avatar
Originally Posted by ChrisCarey
We're still up in the air on this, we may form some sort of package deal
that'd be great - please let us know when you know for sure...BLACK FRIDAY SALE
Old Nov 16, 2011 | 04:28 PM
  #341
CurseDSM's Avatar
Ok long awaited dyno #'s for my ef4. Mind you single walbro on e85 32 psi
Old Nov 16, 2011 | 04:47 PM
  #342
RazorLab's Avatar
Do you have a boost plot?
Old Nov 16, 2011 | 04:52 PM
  #343
CurseDSM's Avatar
ya know funny story no I forgot to log it but I will say it is 32 lbs and full boost about 4700 rpms. Tom was like hey jackass you didn't log everything and I was looking and I was like doh! Another thing I would like to add is I believe my pcv is either going or is shot. I do get alot of brown smoke at wot being I am on e85 and Tom believes that this car should make somewhere in the 580 hp range at 32 psi. So things to check for tomorrow for sure.
Old Nov 18, 2011 | 08:18 AM
  #344
ChrisCarey's Avatar
That's pretty aggressive power for stock block but it looks as if Tom is taking that into consideration for you on the timing front, looking good!
Old Nov 18, 2011 | 08:23 AM
  #345
CurseDSM's Avatar
I will get you some boost plots soon Chris. I know stupid me forgot to add them but I know people want to see the boost and I will try to get them soon.
