MAP EF-series Turbochargers results thread
Old Nov 18, 2011 | 08:47 AM
  #346
Kracka's Avatar
Originally Posted by ChrisCarey
I'm running ~465whp with an EF3 at the moment (albeit on E70) but in regards to the well being of your bottom end I think you'll be just fine.
Overlay vs. your car with EF2 please
Old Nov 18, 2011 | 09:23 AM
  #347
murlo26's Avatar
Originally Posted by kracka
overlay vs. Your car with ef2 please :d
+1
Old Nov 18, 2011 | 03:54 PM
  #348
wanguru's Avatar
[IMG]file:///C:/DOCUME%7E1/ADMINI%7E1/LOCALS%7E1/Temp/moz-screenshot-1.png[/IMG]EF4 results on BP 93 PUMP GAS
Engine Mods:
Fully built 2.3 stroker
AMS CNC head
MAP Rev3 intake
AMS FMIC
ID1000s, single walbro
MAP ported exhaust manifold
MAP MVS DP with ext WG (made a significant improvement)
Hallman MBC
Stock ECU
Attached Thumbnails MAP EF-series Turbochargers results thread-ef4-mvs-mbc-28-5lbs.jpg
Old Nov 18, 2011 | 04:04 PM
  #349
tscompusa's Avatar
full boost right around 4700 ish.. ya theres so much more in Brians car. we only have it at 12deg uptop.
also i gotta laugh how early he started the pull the graph looks odd. i just cleaned up some stuff on his sd tune so im sure hes very happy right now with his car.
Old Nov 18, 2011 | 04:07 PM
  #350
CurseDSM's Avatar
Well its getting cold maybe we should get some more tuning in it makes for more power with colder weather
And yes Tom im happier then a pig in ****
Old Nov 19, 2011 | 11:53 AM
  #351
getsideways's Avatar
Originally Posted by wanguru
Engine Mods:
AMS CNC head
MAP Rev3 intake
AMS FMIC
Hallman MBC
Stock ECU
added to page 1
Brian i will wait for your chart with boost plot and full mod list again
Old Nov 19, 2011 | 09:52 PM
  #352
wanguru's Avatar
forgot to add that the cams are kelford 272s.
Old Nov 20, 2011 | 06:51 AM
  #353
Thats really solid on pump gas, care to share pics and thoughts on the external WG ive been considering it for this winter.
Old Nov 20, 2011 | 10:04 AM
  #354
Jeff_Jeske's Avatar
Here is some data from my latest run on E85.
Mods:
2006 EVO9 SE
Perrin Filter (stock tube)
MAP EF2 (unported) w/HP WGA
FIC 1050cc injectors
Muse LICP
ETS 3.5" FMIC
HKS catless TBE
From the spark plugs to the clutch everything else is stock. I'm sure there is more power in the turbo but I'm not pushing it any harder outside of a dyno. If anyone has MIVEC secrets they can share please do so as that may be helpful as well. I'm simply using the JDM mivec map with my stock cams. I am very open to suggestions......
Old Nov 20, 2011 | 10:25 AM
  #355
sparky's Avatar
Is this with a stock, uncrushed metal DV, Jeff? Have you adjusted the WGA rod shorter yet to see whether or not increasing WG spring pressure and crushing the DV slightly will improve turbo response and thus fatten the power band in the midrange?
Old Nov 20, 2011 | 10:29 AM
  #356
Jeff_Jeske's Avatar
This is with a stock uncrushed metal DV and as for the actuator... I removed the tightening nut and cranked down the actuator adjustment to a little over one eyelet of preload. It took a good yank to seat the rod.
I have verified no boost leaks and solid compression. I even fixed my TB seals to ensure I was leak free to 26psi but after that my boost leak tester blows off the turbo LOL! I'm sure my DV is leaking at high PSI.
Old Nov 20, 2011 | 10:33 AM
  #357
CurseDSM's Avatar
Originally Posted by getsideways
added to page 1
I took a log yesterday but it doesn't look right its really flat but I started at 3k this time and its really really flat but I did make alot more power as Tom said I would for not starting so low.
Old Nov 20, 2011 | 10:40 AM
  #358
CurseDSM's Avatar
This is unofficial, and it was just me dinking around in the car. Tom don't be mad at me posting this because you havent seen it yet. I was in throttle and tring to avoid deer while doing a pull hahaha. There was no changes to the car, and was the same tune and everything as the origional pull only I started at 3k instead of 2k. I will get another one that will be better but I wanted to take a log that had a boost plot. Obviously the graph is pretty ugly but like I said I was just playing around with the car and made 1 pull to see if I could get a better plot.
I found a much better log with the graph on it this one seems more realistic.
Old Nov 20, 2011 | 10:52 AM
  #359
sparky's Avatar
Originally Posted by Jeff_Jeske
This is with a stock uncrushed metal DV and as for the actuator... I removed the tightening nut and cranked down the actuator adjustment to a little over one eyelet of preload. It took a good yank to seat the rod...I have verified no boost leaks and solid compression. I even fixed my TB seals to ensure I was leak free to 26psi but after that my boost leak tester blows off the turbo LOL! I'm sure my DV is leaking at high PSI.
You might try adding either one and a half, to two complete rotations of preload to the WGA. Also, it is a given that your stock uncrushed DV is starting to lift off its seat at 12-15 PSI. These two things combined together can really impact negatively on spool up and ultimately holdback midrange torque and power production by about 20-40 ft/lbs. Don't be afraid to slightly crush the DV. If you can indent the hat on the canister about 1/8"-3/16" that should be enough.
For indenting the top of the DV, find a socket that sits in about 1/4" radially from the outside edge of the canister. I think that it is a 16mm or thereabouts. Insert two slabs of wood on the vise jaws of your bench vise and center the socket on the hat and apply a little press. Pull the valve out and inspect it. You don't want to crush it too much. Just an 1/8".
Old Nov 20, 2011 | 11:25 AM
  #360
Jeff_Jeske's Avatar
I don't think the WG is opening during spool... the high pressure actuator is very tight .... If you look at the boost curve that is pure actuator as my WGDC has no effect on it.
I'll consider indenting the DV but it doesn't seem to leak during a BLT. I may just entertain an aftermarket solution.
As for more power, I'm sure cams, O2 housing, porting and professional tune would help.
