MAP EF-series Turbochargers results thread
There's always a chance it could surge so I'm sure some people prefer just not taking the risk, and giving the buyer more choices for customization is never a bad thing. Others are going to want it just for the larger 3" inlet diameter.
yep, and I'm going to run a 4" intake with a reducer to the 3" housing so there should be plenty of airflow
You could always ask for the 3" inlet w/o anti-surge ports, like my EF2.5
The EF3 compressor wheels seems to have no issues breathing through a standard size intake though, at least from what I've seen.
I'm a ricer and I like the look of the 3" antisurge
Plus I'm trying to push this on the stock block, so if it creates a small amount of lag then that only helps keep my power curve to the right and hopefully my stock block sealed up with no windows
I'd much rather build the block out of choice as opposed to necessity... I need to get my car back on the road. I'm working on it more than I drive it. I only put 4k miles on it and I've owned it for over a year
I got mine with around 44k in october '11 and I still haven't crossed over 50k. I enjoy working on cars just as much as I do driving them, but everyone gives me **** because I work on it more than I actually drive it
Car:03 evo w 70k miles
mods
E70
MAP EF2 ported
turbosmart wga preloaded to 25 lbs
HKS 272 cams
Precision 1000cc injectors
Walbro 255 fuel pump
Grimmspeed 3 port boost controller
AGP front mount intercooler
Synapse bov (new style)
MAP lower intercooler pipe
Nisei upper intercooler pipe w/small battery
megan 02 housing
Perrin downpipe
3" exhaust
ACT hdss clutch/stock flywheel
415whp 386wtq mustang dyno
STOCK intake pipe and tb seals, I think this may be my problem up top. it shouldn't drop off that much, something is restricted, maybe its the stock exhaust manifold also...thoughts?
366whp /335wtq
we also did a 92 octane tune
mods
E70
MAP EF2 ported
HKS 272 cams
megan 02 housing
Perrin downpipe
3" exhaust
366whp /335wtq
Thank you.
You can order them in different spring rates. I was told mine was a 22 psi but we put a tester on it and found out it was only 18 psi spring. you can adjust the arm on the wga to put more tension on it. If you dont tighten it down far enough the wga will stay slightly open and spool really late, my first pull full spool was 5500rpm so we had to tinker with it a bit.
I had selected the 18psi spring when I purchased and when I installed my new turbo it was indeed preloaded to 18psi.
