AEM EMS Get tuning help for your AEM EMS system.
AEM EMS with current Mods
Old Aug 20, 2005 | 06:31 PM
Nvalenti20's Avatar
Does nayone here have an idea of what kind of numbers I should be looking at with my new AEM EMS and 720s when I go to turbotrix on Sept. 3rd? I was wondering if I should bother going now with my current setup or wait until I upgrade the turbo, any thoughts would be appreiciated. Here is my surrent setup...
HKS 272/272 cams
HKS cam gears
Walbro 255
ACT 2600
Nisei FMIC
3" TB w/cat delete
Greddy type S
Samco Hose kit
BR Cone Filter
Grounding Kit
Manual BC set at 18lbs
TurboTrix reflash and custon Dyno tune
My last visit to TurboTrix I made 322awhp and 305ftlbs on 93 octane with this setup, I am adding the AEM EMS and 720s because I plan on upgrading the turbo and getting alky injection soon anyways and I thought I minus well throw them in now. What kind of #s should I be looking at? should I wait to upgrade the turbo and getting alky injection before getting the AEM EMS and 720s installed? Thanks fellas.
Old Aug 21, 2005 | 10:50 PM
fre's Avatar
fre
You should wait in my opinion you will see minimal gains on the stock turbo. I also suggest you go with at least 880s when you upgrade your turbo. I just installed 880s and AEM on my ams 35r kit and it drives 10x better than it did with a flash on the stock ecu with 660cc injectors.
Old Aug 22, 2005 | 08:17 PM
Nvalenti20's Avatar
Wink
thanks for the reply, So with the AEM EMS and 880s I should see similar numbers as you on the track and the dyno I presume. Awesome, I'd like to make over 400whp on 93 octane but don't think its feasible at the moment, but thats what the alky kit is for
Old Aug 22, 2005 | 09:03 PM
fre's Avatar
fre
Actually I ran these times on the flashed stock ecu. I have no clue what it will run with the ems. I will have an idea come Saturday. Keep in mind I have an ams gt35r. 880s and ems on the stock turbo HAS gone this fast but it is very difficult to pull off. I would say a high 11 would be a more reasonable goal on the stock turbo unless you drive like Curt Bown.
Old Aug 23, 2005 | 04:28 PM
Evo Ate's Avatar
In my opinion you should be around the 345 whp, and 320 tq. range with 93 octane. Put a little Sunoco 104 and 22 psi, and see 365 whp.
Old Aug 23, 2005 | 05:16 PM
Nvalenti20's Avatar
nice, yea i thought i would see more when i went to turbotrix but he said i had bad gas so thats understandable. So I should see another 30-40whp with the EMS, 720s and just the alky kit. Which alky/water/methanol injection do you guys reccomend and what name brand? Buschur, AMS??? Thanks again guys.
Old Aug 24, 2005 | 06:46 AM
GTVEVO's Avatar
SMC kit which is built for NOLIMITMOTORS is what I recommend.
Old Aug 31, 2005 | 11:17 PM
IEXCELR8's Avatar
I think you will get around 40hp/35tq increase . Just ask Mark and he can give you the best guess.
Just put the AEM and the alky kit in now. Then turbo/injectors later.
TurbotrixRacing
Turbotrix Racing - Edison, NJ
100
Jun 12, 2015 08:49 PM
paintballproam
49
Oct 10, 2008 07:04 AM
ExViTermini
37
Jun 6, 2006 01:28 PM
MREvolution
Automotosports - Illinois
Mar 14, 2006 08:11 PM
NocturnalEVO
37
Sep 28, 2005 09:01 AM
