Cobb AP: ?s on product, features, and various maps incl Perrin maps go here [merge]
Old Nov 6, 2011 | 11:01 AM
  #736
darthvader's Avatar
the tuning guide explains all the monitors request accesstuner race and its included under the help menu
Old Nov 6, 2011 | 11:09 AM
  #737
GeeDubz's Avatar
Thanks darthvader; exactly the info I've been looking for!
http://cobbtuning.com/products/?id=4916
http://www.accessecu.com/support/doc...bishi_EVOX.pdf
Old Dec 7, 2011 | 08:43 PM
  #738
ice1874193's Avatar
When's flat foot shifting coming?
Old Dec 15, 2011 | 09:52 PM
  #739
johnnnyjeans's Avatar
Hey guys.
I made a thread about safe parameters of cobb tuning values. Please contribute. We all can log. But what do those values mean??!! See link below.
https://www.evolutionm.net/forums/co...draft-1-a.html
Old Dec 20, 2011 | 12:15 PM
  #740
4x4rich89's Avatar
Originally Posted by aiden1983
Ok so I have read about the AP and wanted to know if it flashes the ECU then how is it that it is undetectable after it is unmarried. Wouldn't the flash count increase? So wouldn't this be the same as other flashes? I am new to AP thats why I am a little confused to what actually takes place and why its better than a flash (only in the respect NOT the fact that you can do it yourself and everything else.
bump
Old Mar 19, 2012 | 01:55 PM
  #741
BadKarmaCreepin's Avatar
bump because i've read a bunch and there's still no clear answer...as far as i know.
Old May 24, 2012 | 12:02 PM
  #742
b3n's Avatar
b3n
Has anyone had their screen die on them? I took mine out of my glovebox after a few months of non-use and the entire screen is completely dark. I emailed Cobb to see what they can do, just curious if this has happened to anyone else.
Old May 24, 2012 | 12:24 PM
  #743
Kracka's Avatar
I've heard of it happening in rare instances, but this is why I don't leave my AP in the car. Heat, vibration, etc. isn't good for electronics.
Old Jun 7, 2012 | 06:30 AM
  #744
b3n's Avatar
b3n
Not really an issue anymore...my 2011 came with a new AP. I suppose I'll have Cobb fix the old one so I can sell it.
Old Jul 13, 2012 | 02:03 PM
  #745
Crester's Avatar
When is Version 2.0 maps coming?
Old Jul 23, 2012 | 01:58 PM
  #746
AIM WO4's Avatar
It's due to the heat or cold. If you check Cobb's site, it states this.
Old Aug 8, 2012 | 10:04 PM
  #747
ihatefwd's Avatar
I just bought a 2008 and the ap came with it but I can't read the screen as its too dim. Going to need to get this taken care of quick. I believe they only charge $25 to replace the screen. Wanted to change from this stage 3 Perrin map to a stage 2 Cobb map since I heard the Perrin maps are prone to knock.
Old Jan 3, 2013 | 11:45 AM
  #748
itsmeek's Avatar
On my GT-R's, the battery died during the Cobb w/TCM installation. Is this the case with the EVO as well? Do I need to hook the car up to a charger while doing the install? This is for a '10 MR-T. I do realize that the TCM installation took forever on the GT-R and the installation was fine as soon as I hooked up a charger to the car in trickle mode.
thanks
Old Jan 26, 2013 | 08:00 PM
  #749
Mag00n's Avatar
I've never had a map install take more than 2 minutes, usually ~30secs ...never had an issue with the battery
Old Jan 27, 2013 | 07:38 AM
  #750
MisterHappy's Avatar
Never use a charger when doing a map switch. Never been a issue.
