my daily driver IX 11's! minimal mods
Old Nov 28, 2006 | 08:53 AM
  #76
SterlingEvo's Avatar
Talk about the ultimate setup! A true 11 second daily, that flies WAY under the radar without a wing and basically as quiet as stock!
Old Nov 28, 2006 | 09:17 AM
  #77
Early EVO's Avatar
Dan is still working on it. Maybe with some luck will post up a new time this week with it. If we can get it to run like we want!!!!
Old Nov 28, 2006 | 10:50 AM
  #78
Seranin's Avatar
Great numbers.... any intentions of tweaking the stock catback (3" piping or works muffler treatment), or are you going to leave it alone? (Seems to be working great as is)
Old Nov 28, 2006 | 01:37 PM
  #79
TonyG's Avatar
I'm glad to see I'm not the only one who prefers to keep the stock catback.
BTW, I posted some dyno charts and timeslips recently, comparing the stock exhaust to an open catback. The difference was ~25 whp, or 2.5mph at the traps.
Old Nov 29, 2006 | 10:27 AM
  #80
grenade's Avatar
Originally Posted by vwjeff
Sorry but I gotta call on this 1.
Seen it in person. STFU.
Old Dec 1, 2006 | 01:43 PM
  #81
fusionchicken's Avatar
holy SH*T this is madness....good job!!
Old Dec 1, 2006 | 04:16 PM
  #82
CEB Unit's Avatar
Well my setup will be very similar to yours as well. Currently sitting in my trunk I have walbro 255fp, mbc, air filter and a test pipe. On the way I have a 3in downpipe, o2 housing, GSC 272 exhaust cam and lower intercooler pipe. I'm going to leave the stock cat-back as well but I'm putting in a manuel cut-out for racing duties. I want it to be quiet especially here in SoCal.
120's or bust!!!
Old Dec 1, 2006 | 05:11 PM
  #83
fimotorsports's Avatar
120's or bust!!!
yes I would have loved to do a cutout, maybe I will later though. Made some minor changes, back on the dyno made 335 whp and 420 ft lbs on Dougs Mustang Dyno. Going to the track tonight to see what it does. Dyno'd the stock catback removed and it only showed 7whp difference accross the board, but the boost spiked another 3psi higher... however at the same boost level at 7k still 7whp more
Old Dec 1, 2006 | 05:15 PM
  #84
CEB Unit's Avatar
Definitely let me know what you run. Good luck. check your pm's.
Old Dec 1, 2006 | 06:00 PM
  #85
TonyG's Avatar
Here are my dyno plots for (DP+TP+stock CB) vs. (open DP).
https://www.evolutionm.net/forums/sh...0&page=2&pp=15
The difference is 16 whp (peak), not 24 whp as I previously mentioned.
Old Dec 2, 2006 | 04:49 AM
  #86
just as I predicted 11.42 at 118 mph
Old Dec 2, 2006 | 05:15 AM
  #87
94AWDcoupe's Avatar
Good job again. This car must be a blast to drive. I am going to copy this mod path as well and see what happens.
How much do stock evos put down on this dyno?
Old Dec 2, 2006 | 05:58 AM
  #88
Seranin's Avatar
Thanks for the info... it seems like a solid ~10 lb*ft all over... i'm not sure how much that number would grow if you tuned to take advantage of it, but even if it was 20 lb*ft gain running open vs. the stock catback it's not worth it (to me) for a daily driven car. I am surprised that there isn't more torque gain at the top end as I would figure the increased flow would mean increased restriction with the stock catback.
FIMotorsports - keep us updated! this is good news for those who want to keep a low profile (or hate loud exhausts)
Old Dec 2, 2006 | 06:04 AM
  #89
94AWDcoupe's Avatar
Was your open downpipe the same 3" or just the stock one? Your 8 may open up more than a 9 by dropping the catback. I believe the 9 muffler (with no flapper) flows better than an 8.
Old Dec 2, 2006 | 09:10 AM
  #90
1slowevo's Avatar
Great job Danimal. Once again taking another title in SinCity as the #1 and 2 fastest evo's.
