Someone Shoot Me... Or Help Me Learn How To Launch
Old Mar 8, 2008 | 07:13 AM
blackdemon's Avatar
Originally Posted by S6devil
when i got my tune, they raised the redline to 8000. but this doesnt help (and it also scares me that the engine will blow up).
if i rev up to 6k, and slip or drop (whichever), it revs to the 8000 rpm redline in a split second, and i have to shift into 2nd gear. then by 50mph, i have to shift into 3rd, by 80 into 4th, by 1/4mile well into 5th... the bad start, and high gears all add up to a horrible time
If your rev limiter is at 8k you shouldn't have to change gear into 5th. By the end of the track on 4th gear I was at 7600ish rpm. My rev limiter is set at 7800 rpm.
Old Mar 8, 2008 | 10:28 AM
S6devil's Avatar
my rpm needle is on steroids! its revs up faster than i can comprehend. by 60mph, im in 3rd (and thats with the redline raised to 8000) !!
Old Mar 8, 2008 | 05:42 PM
AK Evo's Avatar
Are you on the stock clutch? If so it may be slipping with such a slow time and low trap speed. On the highway put it in 5th at about 40mph floor it and if the RPM's spike up without the car moving faster you'll know.
Old Mar 8, 2008 | 05:48 PM
izabran's Avatar
dude i pm'd u hit me up ill be at streetwars tomorrow... ill teach you how to drive the car... all jokes aside...
Old Mar 8, 2008 | 06:54 PM
S6devil's Avatar
i have a new clutch, and new flywheel. when i put it in 5th gear, or any other gear for that matter, it moves like its on crack !
as long as its moving, it has enough power to tow a house, but my only problem is a standing start.
Old Mar 8, 2008 | 07:17 PM
blackdemon's Avatar
Tomorrow will be a wrong day for him to practice. since you will be competing. Lets go in the middle of the week. For test and tune. Island dragway. Its cheaper and you get more runs.
Old Mar 9, 2008 | 02:00 PM
saywhen's Avatar
Ok something is wrong here. While drag racing your car is no where near max'd out in 2 at 50mph come on... also 105 is no where near the limit in 4th your car is probably closer to 115.... You 60' time tells me your not going through 1st very fast so unless your clutch is slipping you need to get a ride by someone who knows what there doing. Take up some of the offers you have gotten. Peace
Old Mar 9, 2008 | 02:11 PM
mcwop23's Avatar
actually with an MR i think 105 is about where you would shift from 4th to 5th unfortunately
Old Mar 9, 2008 | 03:35 PM
blackdemon's Avatar
Originally Posted by saywhen
105 seems low regardless of the launch but this is my .02
You need to have the rev limiter raised or disconnect it (search forum for how to do this) make sure you reconnect it when done racing or the revs will fall really slow in between shifts. Now that the car is ready...
Rev it to around 6k-6.5k Let the clutch out just a bit now your ready... let the clutch out slow until the car starts to move then drop it. In reality it will almost feel like you just dropped it but there is a very slight hesitation to engage the clutch before you dump the clutch. Let it out to slow and you burn the hell out of a stock clutch and may get wheel hop, let it out in drop and you will get drivetrain shock. A great launch will get you a low 1.6. Hope that helps. The whole launch is very fast once you master it. If you have a twin disc launch it like your trying to light up a honda civic's tires ie... slip it a bit more.
There are some that can launch at the 5k rev limiter from the factory. I find it really difficult.
Disconnect the rev limiter? Why would you tell him to do that? The rev limiter is put there to save the motor.
Old Mar 9, 2008 | 07:17 PM
Billy@EnglishRacing's Avatar
best thread title ever! It is going to take some practice and trying different things to figure out what is going to work best for you, good luck.
Old Mar 9, 2008 | 07:28 PM
BocaShula's Avatar
lol this thread is kinda helping me too...
Old Mar 10, 2008 | 09:53 AM
saywhen's Avatar
Bad info the rev limiter is there to save the drive train has nothing to do with the motor. The only way he can raise the rev's with the car in 1st is to flash the ecu and have the rev limiter raised or disconnect it. Disconnecting it takes less then a minute and will allow you to launch the car more aggressively. The bottom line... some people can and have launched the car with the factory rev limiter. However it is to low for the masses.
His OP shows he has no clue and is trying to learn. I tried to give good help. My car makes very similar power to his and I went to the track sat and ran two passes...
Pass 1 Pass 2
R/T .050 .120
60' 1.640 1.641
330 4.864 4.862
1/8 7.590 7.590
MPH 91.89 91.89
1000 9.971 9.968
1/4 11.974 11.968
MPH 112.60 112.81
Let the launch speak for itself. Remember if you disconnect the rev limiter, you must reconnect when done racing as it effects the way the revs fall when you shift (they fall really slow). Enjoy
Old Mar 10, 2008 | 11:04 AM
blackdemon's Avatar
Pass 1 Pass 2
R/T .050 .120
60' 1.640 1.641
330 4.864 4.862
1/8 7.590 7.590
MPH 91.89 91.89
1000 9.971 9.968
1/4 11.974 11.968
MPH 112.60 112.81
Ok. I think we are talking about 2 different things. Engine rev limiter and 2 step.
Old Mar 10, 2008 | 11:10 AM
saywhen's Avatar
Yep we were, sorry if I confused.
moreno78065
Jun 18, 2015 07:20 PM
3gEclipseTurbo
Mar 4, 2010 12:09 PM
Raceghost
Apr 24, 2009 09:50 PM
00cls1camaross
Driving Techniques
Aug 8, 2008 01:33 PM
FilipinoEvo
Mar 23, 2004 12:57 PM
