EVO X 1/4 mile thread
Old Dec 5, 2010 | 11:42 PM
  #256
futurevowner's Avatar
Were you still in 4th or shifting to 5th on those runs? Any reason you were only at 32psi instead of 36?
Old Dec 13, 2010 | 02:42 PM
  #257
overboostin's Avatar
no point in going with more boost cuz started to spin in second. and yes i was shifting into fifth with 150feet to go
Old Dec 13, 2010 | 10:32 PM
  #258
If you were spinning anyway you might as well run full power just to see the trap speeds, and i would definitely raise the limiter to stay in 4th for next time out, good trap speeds though i believe its the fastest stock frame turbo evo x.
Old Dec 14, 2010 | 07:10 AM
  #259
bluedevilx's Avatar
didnt you go faster with a stock motor and smaller turbo ?? so you make over 100 who more and have a built motor and went slower????? what happened
Old Dec 14, 2010 | 07:45 AM
  #260
murlo26's Avatar
The smaller the turbo the easier it is to drive. A stock turbo is stupid easy to drive. When you get more and more power/lag it gets increasingly difficult to drive. The launch is much tougher on a higher powered car as well.
You will start to see some FPblacks break into the 10's this next season I would guess... my goal is 11.2 or faster...sure my car should be in the 10's but as I said I know I need to learn the driver mod big time.
The good news is I have no money to make it faster so i will be stuck at this power level for a while learning
Old Dec 14, 2010 | 10:59 AM
  #261
no he went quicker with a smaller turbo and less power, he went faster with the bigger turbo
Old Dec 14, 2010 | 01:06 PM
  #262
Hi pete... how are you?
you are correct since the dyno sheet is still on your wall.
at 423 on your dyno with taller tires 245-45-18 i did go 11.42 at 121.63 without shifting into fifth gear. since i was on 19s and crappy tires i was cutting 2.0 sixty vs 1.7 sixty so that would be your answer. there is always next season.
oh and im glad im still on your mind.
get some 17's and get slicks!!! otherwise get ready for 1.9-2.1 sixtys
dude i had no traction issues before especially at the track so thats the major reason and i was also on taller tires
Old Dec 14, 2010 | 01:09 PM
  #263
murlo26's Avatar
My 275's hook up pretty well, the star specs are very grippy, but we will see with all out launching next season.
Old Dec 14, 2010 | 05:16 PM
  #264
Yea I definitely understand I was just correcting Pete when he said you went fast on the smaller turbo which isn't true since faster usually refers to trap speed. 128 is dam good for not being at full power and having to shift to 5th.
Old Dec 14, 2010 | 08:12 PM
  #265
Thank you. The way I look at is simple. I trapped 128 on crappy gearing that x without over revving the car... Basically getting a feel for it etc. I'm doing one of two things in the spring... 17s small break kit and 26.5-27 slicks or 18x9.5 inch rpf1s with Mickey Thompson et street 2 drag radials 265x40 which is 26.5 inch. This will improve mph and stretch every gear out a bit the same way I had before with 245x45 profile tires.
Old Dec 14, 2010 | 08:25 PM
  #266
murlo26's Avatar
What are you revving to?
By my calculations, my 9k rev limit is good for I think 134...
Old Dec 14, 2010 | 08:40 PM
  #267
Was only till 8400-8500. On need to push harder if cutting 2.0 sixties lol
Old Mar 28, 2011 | 03:21 PM
  #268
11.24 @ 126.6 1.79 sixty foot buschur 2.0, gsc s2's, fp black @ 33 psi pump and meth. ame tm02 19x9 wheels with 255x35x19 nitto invos, 3750 race weight (lol)
Old Aug 17, 2011 | 09:19 AM
  #269
Inverted's Avatar
Originally Posted by ETS Michael
Here is our time slip.
Was there a video of this??
Old Oct 13, 2011 | 07:19 AM
  #270
2003evo8's Avatar
[QUOTE=onpol;8475478]Predator Performance Evo X- AMS Dual TBE,AMS FMIC and IC Pipes,AMS Fuel Rail,AMS 600HP Fuel System and AMS Pressure Reg. GSC S1 Cams and a FP Red Turbo
Video
http://www.grs-motorsports.com/notic.../7julio/29.wmv
[/QUOTE
what bottom end or was the block stock
