evodan2004's attempt at 9s take 1... failed
Old Jun 26, 2011 | 08:14 PM
  #166
wizzo 8's Avatar
For some reason you don't hit the boost you would hit on the streets. I noticed this after logging my runs for the first time last year
Old Jun 26, 2011 | 08:32 PM
  #167
EvoDan2004's Avatar
alright you suns of *****es. ill do it. NLTS. ill give it a go. i am going to talk to sean next week and see if he can set it up in the Fcon for me. i spoke to alex and how he explained it to me makes pretty good sense. so lets give it a shot.
if it works i am not posting any updates. i will avoid the 176 ''i toooooold you so's'' that i would deserve coming. hehe
Old Jun 26, 2011 | 08:37 PM
  #168
LGshow19's Avatar
Originally Posted by evodan2004
every day before a track day the car gets an oil change, trans, tc, rear fluids change, plugs, compression test, boost leak test. i remove all pens and paper from inside for weight. im not joking. hahaha.
today my 10.32 it hit about 37/38. i turned the MBC up 3 turns. on the street i guess its easier for the car to hit 40psi. at the track its another story. next time im tuning the damn thing 5 times.
That pretty funny about the pen and paper Ive seen you in that weight reduction thread. Your really serious about not getting FAT
Im sure youll be trapping higher if you actually were at 40psi. Anyway to verify what boost level your at after adjusting the MBC?
Old Jun 26, 2011 | 08:40 PM
  #169
Evosick2332's Avatar
Congrats dan on the new personal best!! Any time you go faster then before is a accomplisment. Good Luck on your next outing!
Old Jun 26, 2011 | 08:41 PM
  #170
06MREvo's Avatar
BTW Dan...Hallman just came out with a "stiffer" spring for their MBC...If you email them they will send you one for free...I put one in my MBC this past week...It's holding boost very well up top...tapers 2 psi at most...
Old Jun 26, 2011 | 08:46 PM
  #171
EvoDan2004's Avatar
thanks. but i do not feel happy with it. i know this wont happen over night but its just getting rough.
my 10.32 was 37/38psi.
Old Jun 26, 2011 | 08:47 PM
  #172
HyboostN's Avatar
hahaha Good luck brotha!!! Im gonna just be nice and tell you now " I told you so!!!" Best of luck !!!
Old Jun 26, 2011 | 08:48 PM
  #173
EvoDan2004's Avatar
a newER heavy spring? i have the heavy one now. but its about 6 months old. if there is a newer then i must own one.
  #174
EvoDan2004's Avatar
damn you
Old Jun 26, 2011 | 09:02 PM
  #175
LGshow19's Avatar
Oh man you got that single digit pass even if you suck at driving jk... I predict a 145 trap when boost is at 40
Side note: about this new "Stiffer" spring. When was this released? I just picked up a new Hallman pro because mine started to look not so good. Any info would be cool
Old Jun 27, 2011 | 03:56 AM
  #176
milford's Avatar
i would go back and give it a try without setting anything new up. Ive tried the NLTS in V7 and did not really find it to be anymore helpful. If you FFS and do it fast i would be more then willing to bet you improve on those time. Maybe Fcon NLTS works bettter but with v7 the results are not that profound. GL
Old Jun 27, 2011 | 04:06 AM
  #177
CMB's Avatar
CMB
Is your trans giving you some grief? Sounds like its finicky going into gear or its just you taking it easy...
Good luck next time out
Old Jun 27, 2011 | 04:08 AM
  #178
CMB's Avatar
CMB
This is true. When youre out there on the streets tuning your in one gear and it spikes real easy. When you actually go through the gears the boost is lower till you get to 4th gear it seams.
Old Jun 27, 2011 | 06:23 AM
  #179
LGshow19's Avatar
Different loads on the engine in different gears
Old Jun 27, 2011 | 06:31 AM
  #180
06MREvo's Avatar
Correct, you must, as far as I know this spring only came out 3 months or so ago. It is definitely a bit stiffer then the original "stiff" spring I had in my MBC...shoot them an email...
