evodan2004's attempt at 9s take 1... failed
Old Jun 28, 2011 | 10:11 AM
  #196
06MREvo's Avatar
Nlts...
Old Jun 28, 2011 | 12:32 PM
  #197
EvoDan2004's Avatar
Originally Posted by 06MREvo
Nlts...
yes sir.
Old Jun 28, 2011 | 08:11 PM
  #198
HyboostN's Avatar
Hey Dan have you removed your sway bars yet?
Old Jun 28, 2011 | 09:00 PM
  #199
Sean@Iveytune's Avatar
We run the car to 9k on the dyno.
Sean
Old Jun 28, 2011 | 09:06 PM
  #200
EvoDan2004's Avatar
No I have not. I replaced the stock ones with lighter ones though.
Old Jun 29, 2011 | 02:42 AM
  #201
EvoDan2004's Avatar
i spoke to master Ivey till about 1:45am about why my car is so slow. we came up with a few good ideas to try. so adding with NLTS and the heavier boost controller spring ''to hope to help the top end taper'' we will pull off the air filter from the intake pipe. the pipe will still be there but it will have no filter.
friday will be the next track day for me. lets see what happens.
Old Jun 29, 2011 | 05:46 AM
  #202
LGshow19's Avatar
What is the reasoning behind taking off the sway bars? Besides weight reduction? I know Drag racing is straight line, but does the sway bar really hurt times?
EvoDan good luck next track outing
Old Jun 29, 2011 | 06:01 AM
  #203
06MREvo's Avatar
NLTS....haha...
Nice man, glad you were able to talk to Ivey about stuff...Never thought about the air filter, good point...Hopefully you will get that spring tomorrow, took a week or so to get mine...
Old Jun 29, 2011 | 03:11 PM
  #204
EvoDan2004's Avatar
NLTS....haha...
I NOOOOOOOOOOOO HAHA
Sean thinks the air filter could be restricting air flow. He tested the filters a few years ago and found the limits of them which I am already past. So let's try it out.
Old Jun 30, 2011 | 08:21 AM
  #205
06MREvo's Avatar
Nlts...
Old Jun 30, 2011 | 11:16 AM
  #206
BigT's Avatar
Are you going this Friday, July 1st, or next? I plan on going the 15th.
Old Jun 30, 2011 | 11:34 AM
  #207
EvoDan2004's Avatar
this friday. and then sunday.
Old Jun 30, 2011 | 11:35 AM
  #208
EvoDan2004's Avatar
Old Jun 30, 2011 | 11:42 AM
  #209
4g63evoeight's Avatar
NLTS....haha...
a stiffer hallmann spring? i think i have the standard one in mine, hits 32psi but it tapers quite a bit.. maybe the stiffer spring would help
Old Jun 30, 2011 | 11:43 AM
  #210
EvoDan2004's Avatar
i have no clue. i will find out. i hope it is indeed stiffer then the normal stiff spring.
