Hoosiers DOT 245 45 17
I just ordered a set of these and will be using them for th first time this coming weekend at IFO. I was just woundering for those peeps that are or have used these tires, should I do a burn out from the water box or avoid the water altogher and just launch them with out a burn out. Thanx
i use them. i have not done a burn out on them. if you decide not to make sure you go around the water box. if you do a burn out role threw the box and then do you burn out.
best of luck
best of luck
i agree with wizzo and evodan get a feel for them, than you can decide if you wnat to roll thru the water box. burn-outs are hard on everything, so why do one if you don't have to? besides i think its cooler to just roll up stage and book
p.s. can i ask how much for the tires and where did you order them from? G/L
Raceghost
21
Nov 2, 2012 07:47 AM
AcePitcher11
Jan 19, 2010 12:52 PM
