Top 20 Fastest/Quickest Stock Appearing Turbos for 2013!
5LEEPERISAH23I / 6/21/2013 / TSComptuned / Evo 9 / FP BLACK, TSC 2.4L, Stock ECU + SD v7, e85, Street tires, 3345lbs, 630WHP vd/dj / 10.654 ET
Steve went to Atco instead. Cecil sucks right now. Finally got his 10 sec pass! almost mid 10's.
Still at 34psi.
Still at 34psi.
^^Nice! 1.70 60 ft almost knocking a half second off! List updated!!
Also, there are a couple of you that posted in this thread but haven't been added to the list yet. Please make sure to put your info in the correct format like on the first page & you will be added, thank you!
Hello
I am Stamatis from greece, i have an evo6 TME with stock frame extreme tuners turbo, i had a run at 6/16/13 with 25psi boost, stock intake manifold stock exhaust manifold stock throtlle body. Extreme tuners 2ltr engine high cr. Stock gearbox.
M&H 235/60/15 street/strip tires. Vp import fuel. 95f ambient temp.
We had a clutch problem to raise more boost, we hope next time to do something better.
Hello
1.50 60 ft, nice job! Please list your info in the correct format like on the first page. Also this is the first extreme tuners turbo I may put on the list. Do you have more info on the turbo for us? I would be interested in seeing some engine bay pics as well.
Got down to 11.758 @ 116..24 in my 2011 Evo X MR - 20G Turbo, 26 psi, 93 octane
full details here: https://www.evolutionm.net/forums/10863714-post62.html
Sorry correct format:
Stamatis evo6 / 6/15/2013 / Extreme Tuners Built & Tuned / Evo 6 / Extreme Tuners dual ballbearing 63mm, 2.0L high compression setup, stock intake manifold, stock exhsaust manifold stock throtle body/ VPimport, M&H 235/60/15 street/strip tires, 95f ambient temp, stock transmission / 25psi boost / ET 10.539
engine bay
thank you
engine bay
thank you
It's a 20G compressor wheel and housing upgrade from Arashi that leaves the Stock turbine side stock. I guess it would be considered a TD05H-20G at this point. It's really just a short term upgrade since it was around $200 and decided to see if it could really add 30-40 whp with the exta 3-4 psi it holds on the top end. This also gets me closer to the class limits for NARRA Time Trials TT3 class and still has amazing response, only 100 rpm spool loss to 20 psi in 4th gear (2900 versus 2800).
Hiboost / 6/23/13 / STM / Evo X / TD05H-20G / Stock 2.0, Standard Bolt-ons. Hiboost Tuned, 93 octane, 26 psi / 11.758 ET / 117.09 MPH
