DynoFlash [Visit Site]
HKS RS INTAKE - can it filter enough ???
Old Jun 6, 2006 | 03:45 PM
  #61
Kings Fan's Avatar
Originally Posted by Corey
I took my MAF off today and inspected it and the intake pipe and noticed my pipe and MAF sensor was dirty. I took them both off and cleaned the pipe out with some WD40 and washed it out with water, but I don't know what to use on the sensor.
I have almost 52K on my car and I've changed the filter numerous times, but not as often as I should have with the undertray off the car.
What can I use to celan the MAF sensor? I bought some STP throttle body and intake cleaner, but I'm not sure if I should use it or not. I've had some people tell me to use brake cleaner.
Any suggestions?
You can use isopropyl alcohol or electronic cleaner
Old Jun 30, 2007 | 04:30 PM
  #62
Robevo RS's Avatar
what you guys think about my new set up?
HKS RS intake tube,Apexi filter, Apexi induction box.
  #63
Robevo RS's Avatar
sorry double post..
Old Jul 3, 2007 | 12:07 AM
  #64
C6C6CH3vo's Avatar
Wow that sure looks tidy, you also insulated the cast but removed the lower HS - WGA adjustments at the fly
Old Jul 3, 2007 | 12:13 AM
  #65
C6C6CH3vo's Avatar
Wow that sure looks tidy, you also insulated the cast but removed the lower HS - WGA adjustments at the fly.
About the RS not filtering - just change the oil more often, the dirt will just end in the oil filter anyway it won't hurt a thing so long as the filter doesnt build with crud.
You may also need to clean the TB after awhile with the rs filter but other than that a little sand might actually be a source of fiber
Old Jul 3, 2007 | 05:04 PM
  #66
Robevo RS's Avatar
thanks!
rbmxer
Feb 25, 2013 09:53 PM
evo_q8
32
Feb 15, 2010 03:40 AM
DynoFlash
33
Jul 18, 2009 10:00 PM
03RRVIII
Apr 30, 2008 11:04 PM
simevo
Mar 25, 2005 10:48 PM
