E85 Timing Maps
Old May 25, 2012 | 08:37 PM
  #121
doghouse's Avatar
good info
Old Jun 17, 2012 | 08:54 PM
  #122
EVIL_EV0's Avatar
I just want to ask another newb question..... I've found multiple threads saying E85 is fine to run at 12:1 especially during spool up because much richer than that causes rich knock.... but I really need to know if there is danger in running 12:1 out for then entire powerband.
Lastly .... I've been tossing timing at my midrange and still don't think I've hit MBT.... I'd like to post my timing numbers at specific RPMs to see if they pass the smell test.
4000 - 4* - 311 LOAD
4500 - 5*
5000 - 7*
5500 - 10*
6000 - 11*
6500 - 14*
7000 - 16* - 276 LOAD
Does this look OK according to what most of you are running? Like I said I'm nervous to add any more timing at 5500 and above. This is on an EF2 turbo stock 9 cams 26PSI dropping to 22PSI.
Old Jun 17, 2012 | 09:29 PM
  #123
mrfred's Avatar
4500 - 5*
5000 - 7*
5500 - 10*
6000 - 11*
6500 - 14*
Looks pretty reasonable. What rpm does the turbo reach the torque plateau? I would have thought it would be around 3500 rpm. Are you tuning on the road? If yes, my experience is that road tuning does not yield as repeatable results as on the dyno. If you've got the rest of your tune dialed, I suggest reserving a dyno for an hour and doing some timing sweeps to find MBT.
Old Jun 17, 2012 | 09:30 PM
  #124
Jim in Tucson's Avatar
12:1 across the board is fine. E85 has a much wider 'happy zone' for AFR than does gasoline. I've seen others safely run from 11-13:1 and live to tell about it. Stick with the 12:1, you'll be just fine.
I think your timing is still low. You are not likely to be at MBT yet.
Jim in Tucson
Old Jun 18, 2012 | 05:23 AM
  #125
PrimerSdime's Avatar
Those timing numbers look pretty decent to me but still a little mild. Fyi, I'm running 3 degrees advance at peak torque to 18 degrees advance at 7500 on my fp black at 25 psi. I think it will actually take more timing, but I haven't had a chance to throw it on the dyno.
Old Jun 18, 2012 | 07:18 AM
  #126
EVIL_EV0's Avatar
Thank you for the quick replies! You all are very helpful! The ef2 hits peak tq at 4k. I don't want to smoke the bottom end so timing is tame down low. I'm road tuning and do not have a great place to tune. Maybe a dyno is the hot ticket now.
Id love to see more timing maps from similar sized turbo cars.
Old Jun 24, 2012 | 05:53 AM
  #127
boostleak's Avatar
Newbie here, Hows my timing map look?Tuned on E85 a couple months ago. Thanks
Old Sep 2, 2013 | 11:15 PM
  #128
NightCat's Avatar
I guess I'll play
Old Sep 17, 2013 | 12:59 PM
  #129
curamrdan's Avatar
Can anybody post good proven map for evo8 with stock exhaust, please?
Old Sep 17, 2013 | 01:52 PM
  #130
hiboost2.0's Avatar
What other mods do you have?
Old Sep 18, 2013 | 04:50 AM
  #131
curamrdan's Avatar
Smaller 9.8 turbine, bigger tanabe downpipe(my GSR260 have small cat here originaly)+decat pipe. Stock mufflers. And HKS style intake+filter. Injectors 750cc due E85, load set around 220 peak to 170 at limiter.
Just asking for some good " map, to inspirate. Now runing simply + 2degs.
Old Sep 28, 2013 | 10:18 PM
  #132
detroit pistins's Avatar
Great thread. Thank you!
Old Dec 18, 2013 | 11:43 AM
  #133
Toekneee!'s Avatar
Just made the switch. From my understanding E85 tuning is different from pump gas tuning. You can't just increase timing until knock. Anyways here is my timing map. Is it too advanced in the midrange?
AFR ~ 12.1 WOT by redline
Car feels great and pulling strong. Just want to know if I'm doing internal damage I cannot see. Thanks guys!
Old Dec 18, 2013 | 11:57 AM
  #134
tkklemann's Avatar
Originally Posted by Toekneee!
\From my understanding E85 tuning is different from pump gas tuning. You can't just increase timing until knock.
Correct.
Old Dec 18, 2013 | 12:30 PM
  #135
ReaperX's Avatar
What load curve are you running?
