e85 qucik questions
Old Dec 5, 2013 | 02:20 PM
steven121's Avatar
e85 qucik questions
cannot seem to find the answers
I want to tune e85 sometime in January, im convinced and I want to do it, I like how it cleans the engine thats sweet.
Local tuner says I need the grimspeed 3 port boost solenoid for a dual map conversion? Is this true, I only ask because if I want to go on a road trip with my car I want to switch to 93 and once I get to my destination I will put e85 back in. "CURRENTLY RUNNING HALLMAN PRO BOOST CONTROLLER"
Im planning on purchasing a new wide band soon, but If I dial out the idle ltft and mid ltft without boost and set the scaling right do i need a wide band to confirm the afrs are correct for cruise if I want to run close loop? Or do I need to do open loop?
I have all the mods required 1000cc and 255 walbro fuel pump, I know how to tune.
just need these 2 questions answered. I did research and keep seeing the same questions "what is needed to convert...
Old Dec 5, 2013 | 02:33 PM
grazzo77's Avatar
How many miles on the car? I would be prepared to go through a few sets of injectors. That cleaning process you are fond of requires all that gunk to go somewhere. Yes, you will need to have a electronic boost controller for map switching. Oh BTW I doubt a single 255 is going to do it. I would think Wideband and a 4 bar maps sensor would be all requirements. Might think about a good Ethanol content analyzer too. Good luck. It's worth it.
Old Dec 5, 2013 | 04:48 PM
Sounds like youre close to ready
Your 1000cc injectors, Walbro 255, 3-port solenoid & the dual maps (TephraMod) & youre set
Will you be flashing in Tephra 7 or 5 for your dual maps?
Not sure about the open/closed loop question. Im not a self tuner
Also, the gunk issue is caused by PIB in the 15% gas. We have a thread dedicated to it. Basically you just want to flush your engine w/the normal high octane gas periodically to flush out the gunk then switch back
https://www.evolutionm.net/forums/e8...nk-e-85-a.html
Old Dec 5, 2013 | 06:11 PM
steven121's Avatar
Bought it with 50k
2 years I i have 74k on it
Thanks man thats one thing i need to buy
Old Dec 5, 2013 | 06:13 PM
steven121's Avatar
Yea im doing the tephra v7 flashover with dual maps, im usig the intercooler sprayer to flash over I like that idea.
Ill check that thread out I like a clean motor makes me feel comfortable
Old Dec 5, 2013 | 11:09 PM
steven121's Avatar
Well since I need a 3 port for dual
Can i use a boost controller to run solely on e85 and when i get my 3 port boost solenoid copy all my 3 85 fuel, timing and inhector maps over to the alternate on the tephra?
I want to get this done possibly in 2 weeks
Old Dec 6, 2013 | 05:21 AM
You'd be better off posting this up in the Engine Mgnt forum. This sub forum is a bit sleepy
Old Dec 6, 2013 | 05:26 AM
st0mp860's Avatar
I wish we had E85 in CT!
Old Dec 6, 2013 | 06:26 AM
David Buschur's Avatar
You do not need to change boost controllers, you simply need to re-adjust the boost with the controller you have when you switch between fuels…..
Old Dec 6, 2013 | 10:05 AM
grazzo77's Avatar
David Buschur promoting manual boost control. Now way!
Old Dec 6, 2013 | 10:14 AM
PureDrivePerformance's Avatar
I'm not sure what you mean that it cleans the engine. Can you explain or links to what you mean.
As Buschur mentioned you do not need a 3 port to run dual maps. I ran a mbc for a few years on dual maps, but now run a hybrid set up.
Yes, you need a WB to confirm the AFR's. Even if the LTFT's say 0 or close to 0 the o2 sensor maybe off. It's hard to confirm without a WB.
Old Dec 6, 2013 | 11:20 AM
steven121's Avatar
Thanks local tuner says I should I will be anyways just want to go e85 soon
Old Dec 6, 2013 | 11:25 AM
steven121's Avatar
There is a thread when a guy ran e85 and it cleaned is motor within 3 years and he checked his parts everything looked good. But that's over time though.
I will buy a wideband sensor and and convert during christmas week
Old Mar 2, 2014 | 08:12 PM
Oxford's Avatar
Duals maps FTW. Totally worth it!
Jp7
E85 / Ethanol
64
Nov 27, 2017 12:07 PM
Dr. Jekyll
Apr 1, 2016 08:42 AM
LaXGSR
14
Apr 7, 2010 08:09 AM
xhomm02
Aug 25, 2009 11:15 PM
