Oil Consumption with E85
Old Aug 18, 2015 | 07:32 PM
mrr5049's Avatar
autocrossed for the first time with my E85 tune, plenty of soot on the back trunk lid and the oil level was definitely down to around the 3/4 mark from close to full. anyone noticed severe oil consumption issues during autocross or track day duty? whats is average? Thanks.
Old Aug 18, 2015 | 07:41 PM
mrr5049's Avatar
I do not see the same kind of sooty mess on the trunk when I autocross with the pump gas (93) tune ...
Old Aug 18, 2015 | 08:21 PM
RazorLab's Avatar
I've been using Ethanol for 7+ years in my cars and haven't noticed any difference in oil consumption compared to pump gas.
What kind of AFR are you running?
Old Aug 18, 2015 | 08:37 PM
ridenrunwv's Avatar
Are you running significantly higher boost on your E85 tune?
Old Aug 21, 2015 | 04:16 AM
badwheel's Avatar
It sounds like you are pressurizing the crank case and pushing oil through the motor. i don;t think it has anything to do with e85. Did you check to make sure you don't have a vacuum line missing somewhere?
Old Aug 30, 2015 | 10:23 AM
speedracer 4g63's Avatar
Never had an issue with oil consumption on any e85 car I've owned especially Evo. Issue might be elsewhere. Did you have oil consumption issue on pump gas auto crossing the car?
Old Aug 30, 2015 | 02:34 PM
EvoGSR8's Avatar
Might be your turbo from e85 boost
Old Sep 1, 2015 | 08:34 AM
mrfred's Avatar
+1. pushes oil past the shaft seals for some turbos.
Old Oct 15, 2015 | 08:55 PM
Thoe99's Avatar
I have an 03' and tracked it heavily for years on E85. To this day, it still does not leak a drop of oil between changes. Lucky I guess?
Old Dec 21, 2015 | 06:24 PM
iownedu's Avatar
I havent had any issue like this with e85. I assume you are running a higher boost with the e85? Maybe you are getting some blow-by past your rings?
Old Jan 6, 2016 | 02:56 PM
kalen2's Avatar
What turbo are you running? It could be burning some oil up if its under heavy use also.
Old Nov 1, 2016 | 07:55 PM
supak1111's Avatar
IMO Autocross in general burns more oil because you will have your engine oil slushing around the engine like crazy and more will get stuck in oil rings and other places.
Old May 2, 2017 | 05:54 PM
WelDun1's Avatar
i had this problem in my STi. But i think like other here have mentioned that bcuz i was running higher boost on ethanol, i was burning more oil and having a lot more blow by
mayhem
Mar 11, 2005 07:32 AM
propellerhead
Jun 13, 2004 03:14 PM
bluevilevo8
22
Feb 21, 2004 02:46 PM
josch
10
Jul 24, 2003 08:10 AM
Chris in HB
Jul 10, 2003 02:21 PM
