Data Log Lab...
Old Sep 4, 2006 | 07:55 AM
  #31
MalibuJack's Avatar
Make sure you have the EVOSCAN.TXT file set up as your universal definition.. In Dataloglab its under options in one of those tabs.. Otherwise it'll try to use some other one (I'm not sure which) and It'll probably get that error.
Old Sep 5, 2006 | 11:13 AM
  #32
nj1266's Avatar
Thanks Malibu. I was able to get it to work.
I need to ask for a favor from you. Can you please add an LM-1/LC-1 definition to the Evoscan.TXT file that you created for datalog lab? Is that something that can be done. If I knew how to do it, then I would.
I manually entered AFR numbers into the LM-1/LC-1 column of an Evoscan log, but the datalog labe does not display it since the Evoscan.TXT does not have that definition. Would Datalog lab display the AFR values if the definition was added?
Thanks Malibu
Old Sep 5, 2006 | 02:49 PM
  #33
mchuang's Avatar
Thanks Malibu
According to EVOMAD the LM1 will be supported in the next update of evoscan along with load and other things found. Suppose to be out shortly.
Old Sep 27, 2007 | 05:31 AM
  #34
Zamot's Avatar
Just barely tried DLL now (don't think it is set up right yet, haven't tried)..
I'm guessing the Zeitronix-stuff should be added to the Evoscan.TXT file as well?
Old Nov 1, 2007 | 12:16 PM
  #35
Inprogress's Avatar
I'm using these values for the gear ratios under the custom car definition
http://www.sportcompactcarweb.com/ro..._ix/index.html
What other settings should I change to make this as accurate as possible? There are multiple settings, like the graph smoothing factor, dyno correction factor, and the drive wheel dimensions...
Help would be appreciated!!
btw, I assume I can't just use the EVO VIII 5-speed as the car's definition right?
Thanks
Old Dec 29, 2007 | 09:28 AM
  #36
LV///R's Avatar
Hate to bring this back up, but where do you find the definitions for the IX?
Old May 26, 2008 | 04:26 AM
  #37
ineedparts's Avatar
gay, i cant get nothing to work, i dont even know how to get it started. anyone charm in on this? jack plz?
Old May 28, 2008 | 02:52 PM
  #38
Evo8Emperor's Avatar
actually now that this was brought back. MJ what do we need to do for this to work for EvoScan 2.2 ? Should it just work or do we need to change anything ?
Old May 28, 2008 | 05:48 PM
  #39
MalibuJack's Avatar
Don't know actually, I haven't used Evoscan since I developed the original dataloglab file that worked with both Evoscan and Mitsulogger. Odds are pretty good that you'll have to edit the file a bit.
bbarnhill
May 4, 2021 08:32 AM
kliped
Mar 20, 2016 05:01 PM
richardjh
May 24, 2013 01:53 PM
JrCRXHF
Jan 31, 2012 11:10 AM
Vibrant
Feb 9, 2010 04:11 PM
