MIVEC tuning
1. Tune the mivec map
2. Tune the AFR
3. Set the boost
3. Tune the AFR
4. Tune the timing
5. Set the final boost
6. Refine the timing
7. Refine tune AFR
8. Refine the timing
9. Verify results under multiple specific driving conditions.
2. Tune the AFR
3. Set the boost
3. Tune the AFR
4. Tune the timing
7. Refine tune AFR
I spent about 4 hours on a buddy's dyno the other day and this is what i did.
I did a baseline run: 251 awhp (see chart)
Stock map with JDM RS Mivec: few more horse, boost sooner
Stock map with John's mivec in this thread: better than JDM RS
Stock map with radical mivec in this thread: not bad at all (see chart)
JDM map with RS mivec: more than with the stock map
JDM map with John's mivec: Little better still
JDM map with radical mivec: 273 awhp and boost about 700rpm sooner!! (see chart)
My setup: '06 RS BONE STOCK!!! No MBC, stock exhaust, stock intake and filter. I bought this car last week and have not changed a thing.
I think the jdm map refers to the timing and fuel maps found in the jdm IX gt map floating around. I would not recommend using it. My tune now is completely custom and tuned for my elevation.
I didn't post every condition listed, just enough to illustrate my point.
I'm still trying to understand this. Doesn't a greater amount of intake cam advance give better cylinder filling and thus better VE in this rpm range? If so, wouldn't it be better to leave the intake cam at max advance and then tweak fuel or timing to deal with the knock?
The intake cam has a 130* centerline, 120* lobecenter seperation angle because the exh has a 110* centerline. This yields 18* of overlap with stock cams.
On the dyno, I have found that advancing the mivec past 6k will bring the peak hp up sooner and stay flatter but not actually increase peak numbers, this might be worth a 2mph difference in the 1/4 mile that John has been seeing. Same amount of peak horsepower, but for a longer duration.
Depends on the car and mods as well, some cars and mod combos, it isn't as 'effective'.
I'm not sure more MIVEC requires less ignition timing (not in the midrange anyway), I've not observed this personally. I run 30 degrees MIVEC midrange and 7 degrees of timing at 25 PSI with knock sums 3 or below on 93 PON/99RON. Since I hold this boost to 6000 RPM then peak power does arrive early. As I mentioned before, perhaps we should 3d map the MIVEC rather than just define it by RPM. We do this with ignition timing, and it makes sense that load is a proxy for VE as higher load on a smaller turbo will give lower VE as the EGBP rises when the turbine chokes (or the compressor chokes and the turbine is spinning faster to overdrive it).
More overlap when the exhaust manifold pressure exceeds the inlet manifold pressure tends to give more pollution of the fresh air charge from the end products of combustion that remain in the cylinder. This encourages knock. I've noted this on my engine, but I push the top end boost harder than most on a given size of turbo because I get more airflow. If I don't swing the inlet cam back to zero at high revs I get detonation and the car accelerates no faster.
If you run tame top end boost or a big turbo then it may tolerate more overlap, and might even improve VE from having the overlap as the exhaust gas momentum helps pull in the inlet charge.
Fully agree with this last post. I think there needs to be a clear distinction between changing the VVT when using the stock turbo and exhausts components and aftermarket turbos, cams, exhausts etc.
I have tested with a multitude of variants (including cossie cams which are the best I have seen so far) right through to GT3076 with an external WG and a 3' pipe.
On a large turbo (35/30 etc) and assuming cams are ground to a 131 centre line employing 3 deg at ~7200 and 5 deg at ~6500 makes a huge difference in how the car responds up top (careful you will need to tune AFR on these changes). It does not add more power, that’s your timing, but it flattens and carries the power curve.
On a stock turbo I suggest you leave the vvt at 0 above 6000. EGBP os too high and you looking for trouble regardless of meth or high octane use. (dynapack hub dyna tests)
Interesting discussion. Keep on testing!
I have observed that the AFR gets richer if overlap is increased (10 deg), especially above 6000 rpm.
Would your comments above apply to the Evogreen too?
Thanks!
Any more tips???
