MIVEC tuning
Old Oct 7, 2007 | 11:43 AM
  #361
JohnBradley's Avatar
A non typical rpm scale is sometimes part of the power secret. Changing the rest of the map without using the listed rpm wont always offer the same results.
Old Oct 7, 2007 | 01:29 PM
  #362
uSmC_08's Avatar
So you're saying it's better to use that non typical RPM scale for more power then?
Is there a quick way to copy that MIVEC ROM rather than changing it cell by cell in ECU Flash?
Sry, I'm still a newb at Ecu Flash
Old Oct 7, 2007 | 03:02 PM
  #363
Mr. Evo IX's Avatar
Originally Posted by 23r0k001
i have that same prob. need a keygen but no where to be found.
buy it and support the developer. If you already paid then just email him and he'll send you what you need. The product is worth the cost or if you really just dont want to pay use the free alternative.
Old Oct 7, 2007 | 03:05 PM
  #364
Mr. Evo IX's Avatar
Originally Posted by uSmC_08
I wanna try this! But can you please re scale for the normal RPM scale?
Please! Thanks
I doubt the rescale will account for very much in this case as the 4250 is about where the ECU would interpolate between 4000 and 4500.. or at least that's how it looks to me. You could probably leave the 4250 out and be just fine. Normally when I rescale the Mivec's I extend the rpm range to redline.
Also, I was in a hurry and ran it without the rescale. I'll set it up the right way and will log it tommorow. I did get a little power up top too maybe 5 hp so that could be differences in the run. However, this mivec map feels really good from idle to spoolup! it's a keeper.
Old Oct 7, 2007 | 08:35 PM
  #365
uSmC_08's Avatar
I just saved this MIVEC map in ECU Flash
Is this safe to use for the mods in my sig?
Also, can anyone please tell me how to use a MIVEC map that someone posts QUICKLY, without having to go column by column and making the changes? That took me forever!
Thanks!
Old Oct 8, 2007 | 06:30 AM
  #366
JrCRXHF's Avatar
I just went cell by cell and did it
It took about 20 min
I ran the map from NJ and i did not see any knock at all on my mods which is just a cat back and MBC with a air filter so for what that is worth to you.
I think you are going to want to log and see what your car likes if it is safe or not is going to depend on more then just your mivec map you are going to want to look at timming and fuel if you get knock.
Old Oct 8, 2007 | 06:46 AM
  #367
23r0k001's Avatar
Thanks!
CEL Fix: Is this the foulers for the o2 sensor on the test pipe?
Old Oct 8, 2007 | 06:59 AM
  #368
Mr. Evo IX's Avatar
Normally mivec map changes will not cause knock. The exception being too much advance on the top end, especially with 91 octane.
Old Oct 8, 2007 | 08:12 AM
  #369
Ralph's Avatar
I was forced to tune out some partial throttle knock after running NJ's posted map. 91 California Octane. I'm sure it wouldn't be a problem on 93 octane though..
Old Oct 8, 2007 | 08:15 AM
  #370
Ralph's Avatar
Adding to this, I do have lean spool disabled..
Old Oct 8, 2007 | 09:59 AM
  #371
Jeff_Jeske's Avatar
Has anyone else noticed their car being a little mivec sensative at partial throttle second gear when cold?
Old Oct 8, 2007 | 10:35 AM
  #372
23r0k001's Avatar
In reference to which Mivec map; NJ or SC?
Old Oct 8, 2007 | 01:32 PM
  #373
uSmC_08's Avatar
Yes
Old Oct 8, 2007 | 01:54 PM
  #374
Jeff_Jeske's Avatar
As soon as I switched to the RS map... (now NJ/JB) ... I noticed my engine feel tighter when cold. Once warmed up its fine.
Old Oct 8, 2007 | 02:50 PM
  #375
Mr. Evo IX's Avatar
Was it in the 70-100 load columns 2500rpm?
