AEM UEGO Serial Cable Instructions
The only "bug" I have with 2.7 is for some reason it won't display or clear OBDII codes... I already sent a trouble ticket to Hammish... I am glad that I still have OBDII Scantech installed!
If you still need a copy of V2.5 pm me your email address
When I log, it works for a split second then stays at the same AFR. I upgraded to 2.7 and the problem is solved.
However, I don't like the idea of not being able to read/clear codes. Never know when I may need to do that.
Jay: I'll hit you up, today, for 2.5.
Very strange. Jay @ boosted tuning says he's heard of this problem before.
I'm not sure why everyone buys those connectors to solder to. I just used an old serial cable I had lying around and soldered directly to the pins on the male side. Then I bought a serial > usb 1 foot converter (ideally its best to keep this short) and connected it to my laptop.
Btw has anybody figured out how to fix the evoscan 2.7 logging for the UEGO? I can log it with mitsulogger but evoscan shows ~10.7 all the time...
EvoScan v2.8 works great with AEM UEGO for this. Log a support call if its still an issue, I can connect remotely to take a look.
what about connecting the AEM directly to the ecu, less usb cables then?
more links at the bottom of this page:
http://www.evoscan.com/technical-veh...ideband-review
