AEM UEGO Serial Cable Instructions
Old Jul 11, 2009 | 05:44 PM
  #196
bustin's Avatar
Hey guys that are checking out this thread. Please refer to the link above. I posted up some info on how you can hopefully get your stuff working!
Old Aug 19, 2009 | 02:02 AM
  #197
kaj's Avatar
kaj
Originally Posted by Fast_Freddie
Here is a direct link to the for sale thread I started for the serial cables...
https://www.evolutionm.net/forums/sa...g-evoscan.html
i'm not allowed to view the thread.
Old Aug 19, 2009 | 04:10 AM
  #198
Fast_Freddie's Avatar
Veteran: Navy
Got deleted as I am not a vendor...
Old Sep 18, 2009 | 12:49 AM
  #199
funks's Avatar
bump.
Old Oct 7, 2009 | 06:02 PM
  #200
evodave's Avatar
From: driving the 10 second beast in ohio or running lightmods.net
Can someone email the instructions to evodave@gmail.com
Old Oct 7, 2009 | 09:59 PM
  #201
Veteran: Navy
e-mail sent
Old Oct 8, 2009 | 06:52 AM
  #202
rogue's Avatar
I may have one laying around somewhere.
Old Oct 8, 2009 | 07:22 AM
  #203
Clipse3GT's Avatar
What I am using is a Ethernet jack that is wired in, then I run a Ethernet to serial cable, the I have a serial to USB cable from there. It works as well. Cost me $3.99 to make.
http://www.microcenter.com/single_pr...uct_id=0216022
Ethernet
Pin 3 (BLACK) to AEM UEGO (BLUE) wire
Pin 5 (GREEN) to GROUND
Need Cable
USB to Serial Cable
Old Oct 13, 2009 | 12:59 AM
  #204
80210's Avatar
What wire do you use to ground the data log cable from port 5? Is there a size I can buy from somewhere?
From what I read you have to ground both the gauge wire and the serial port wire.
Old Oct 14, 2009 | 03:51 PM
  #205
funks's Avatar
You can just get the ground from the chassis, or tap onto the gauge's ground.
Old Oct 14, 2009 | 03:52 PM
  #206
funks's Avatar
Originally Posted by Clipse3GT
Need Cable
USB to Serial Cable
I think this will end up costing people more than the FTDI MM232R stuff pictured above especially when the laptop only has USB ports (as you'll still have to buy a serial->usb adapter).
Old Oct 15, 2009 | 01:20 AM
  #207
haseeb's Avatar
do i need all the same proceedure if im getting my car tuned by mellon ?
email remote tuning by mellon is wat im talking about ...
ive got aem uego wide band ,1.3u open port tactrix cable now getting evo scan .
any thing alse i really need ?
thanx
Old Oct 17, 2009 | 12:21 AM
  #208
haseeb's Avatar
any body ?
Old Oct 17, 2009 | 01:29 AM
  #209
Veteran: Navy
Originally Posted by haseeb
any body ?
Just make the cable as per the instructions and get a serial to usb adapter...
Old Oct 17, 2009 | 11:24 AM
  #210
funks's Avatar
Another USB Option, that's even easier to use
1) Cut off the female section of the 4-pin extension cable (leave the male section of the connector alone - it plugs into the the dongle).
2) Connect the GREEN WIRE from the cable -> BLUE wire on the AEM GAUGE.
3) Connect the BLACK WIRE from the cable and TAP onto the BLACK wire from the AEM GAUGE (or just hook it up to the chassis).
4) Heat Shrink tube the electronics..
Note the ORIENTATION of the cable when plugging it into the dongle
If you follow this picture and positioned the dongle sideways, the black wire should be on top and the yellow on the bottom.
