AEM UEGO Serial Cable Instructions
Old Sep 2, 2008 | 05:30 PM
  #136
felickz's Avatar
Is the Uego considered an "accurate" wideband? Do you need to calibrate?
Old Sep 29, 2008 | 12:08 PM
  #137
fostytou's Avatar
EvoM Community Team
You cannot calibrate the UEGO. The proper resistor is laser etched into the connector before shipping.
FYI, the radio shack serial connectors usually have a small 1 and 9 marked on the pins that are the correct ones, so there should be no way to get turned around!
Old Nov 12, 2008 | 01:18 AM
  #138
piotr4net's Avatar
Hello, I try to log AEM UEGO wideband in EvoScan 2.5 and I got message:
Error: Object reference not set to an instance of an object.
Info: Datalogger Ended
In hyperterminal everythink looks OK
Where is the problem?
Old Nov 12, 2008 | 08:23 AM
  #139
piotr4net's Avatar
I solved problem, I changed in International Settings (Control Panel) separator from "," to ".".
Old Nov 18, 2008 | 07:12 AM
  #140
DDATuned's Avatar
Hey guys and please excuse my computer ignorance but why can't you wire the blue wire to a wire coming off the ecu ? It seems like it would be much less of a head ache and will cost you no money. Also instead of buy these wires could you possibly wire the blue wire to the back of the obd2 connector on the car ?
I just dont understand why you have to use all of these adaptors. I had this same gauge in my dsm and had everything wired right to the ecu so it always logged no matter what.
Can someone just clarify this for me before I start gathering rhw matarials I need to log threw evo scan. Better yet before I pay someone to make it for me lol.
-Remy
Old Nov 18, 2008 | 01:48 PM
  #141
steadly2004's Avatar
-Remy
I bet all it would take would be for one of the ECUflash GURU's to write up some code and it would work.
Old Nov 18, 2008 | 02:08 PM
  #142
DDATuned's Avatar
Well one of the gurus here needs to make it so we can use our wbo2 on the same input as the rear o2. Then just wire the blue wire to the rear o2 input and bam , can log all day.
I know I know .. easier said than done You guys have done a great job so far. I am looking forward to learning all I can in this section.
-Remy
Old Nov 22, 2008 | 09:10 AM
  #143
51's Avatar
51
I will be doing this soon but I have a question. What do you do with the white wire 0-5v output? Does it need to be connected? If it does need to be connected where did you connect it to?
Old Nov 22, 2008 | 09:40 AM
  #144
Mr. Evo IX's Avatar
The white wire is not used unless you are feeding the WB signal into a EMS. Heatshrink or electrical tape it so it doesnt short on anything.
Old Nov 22, 2008 | 05:17 PM
  #145
51's Avatar
51
Thanks.
Old Nov 25, 2008 | 06:25 PM
  #146
lan_evo_mr9's Avatar
Does anyone have a definitive parts list and instruction guide on how to use the uego with vista that is gaurunteed to work properly with no bs?
Old Nov 26, 2008 | 08:07 PM
  #147
fostytou's Avatar
EvoM Community Team
-Remy
You can already: https://www.evolutionm.net/forums/sh...d.php?t=337823
...but its much more inaccurate than the serial output. This is seriously like $8 in parts for an incredibly more accurate signal, come on people!
Old Nov 27, 2008 | 05:44 PM
  #148
Old Jan 15, 2009 | 01:23 PM
  #149
Sliver05nr's Avatar
Originally Posted by trboboost91
actually i bought this cable hoping to get my logging up and running and found
this cable comes with no driver for windows vista. if your running windows 95,98,ME,or XP your good but if you have an up to date OS your screwed.
DON'T BUY THIS CABLE IF YOU HAVE VISTA I JUST GOT OFF THE PHONE WITH DYNEX AND THERE IS NO DRIVER!!!
Any one else have any suggestions on a cable to work with this and vista?
http://www.bestbuy.com/site/olspage....=1110263657278
I ordered and received this same cable today, and the cd included does now come with drivers for vista, I'm havent been able to make sure it works yet, but the drivers are available now.
Old Jan 21, 2009 | 12:35 PM
  #150
Spish's Avatar
Did mine last night using this thread, works like a champ!
