E-85 and EcuFlash
Old Feb 11, 2007 | 06:43 PM
  #106
l2r99gst's Avatar
Updates during cold winter?
PVD04,
I see that you are in Illinois like me, so since we just went through a couple of weeks with subzero air temperatures, not to mention like -30 wind chills, how much trouble, if any, did you have starting your car on e-85? I'm pretty sure the winter blend over here is more like e-70, but I'm curious if you had any problems starting in the cold. I'm very interested in converting to e-85 (a pump is about 5 mins from me) and just want to gather as much data as I can. Also, do you have stock ignition setup (coils, etc)?
Also, I have another question that I can't wrap my head around for some reason:
E-85 is electrically conductive, whereas gasoline is not. Our fuel pumps are in-tank fuel pumps and our wiring to the pump is exposed. So, I think I may just be missing something obvious here, but whats keeping the + and - on the pump from shorting out and either blowing a fuse or worse yet, starting a fire/explosion (small chance with lack of enough O2 in tank)?
I've been reading up a bit on the GM FFV vehicles and some research papers where some college students have been converting cars for class projects, and I have seen a few mentions of GM electrically shielded fuel pumps. A brief search for these didn't turn up much more information. That's the only thing that has me somewhat confused/worried at this point. The rest I am comforatable with. Can anyone clear this up for me?
Thanks,
Eric
Old Feb 11, 2007 | 07:19 PM
  #107
cfdfireman1's Avatar
Gasoline LEL of 1.4%, a UEL of 7.6%
Ethanol LEL of 1.2%, a UEL of 8.2%
Unless you left the cap off the tank driving down the road I don't see how you would get into the range.
Old Feb 11, 2007 | 08:10 PM
  #108
l2r99gst's Avatar
Thanks for the info on the LEL and UEL. That's part of the data that I was missing. Doing a quick search, it looks like E85 may be 1.4% - 19%.
But, OK, that should settle the potential for fire/explosion given that not enough oxygen is present (like I assumed), but what about the electrically conductive properties of E-85? Why wouldn't the pump circuit be shorted out upon contact with the fuel?
Eric
Old Feb 13, 2007 | 10:53 AM
  #109
PVD04's Avatar
Originally Posted by l2r99gst
PVD04,
I haven't had any issues with cold start other than the car requiring a few more cranks than it did with gasoline. I was concerned a few times that it wouldn't start because the cold temperatures combined with a mini battery and a few extra cranks causes those last couple of cranks to be a bit slower than normal. It fired up every time though. I usually let it sit for 30-60 seconds before driving and haven't had any other issues. My car is down for a little while because I'm swapping a 2.3 stroker block and ported race head into the car. I dropped them into the car Sunday night but I still have to hook up the wiring harness, put on the accessory belt, and reconnect the front axles. I'm hoping to be done with it tomorrow night but these things always take longer than expected.
-Paul
Old Feb 13, 2007 | 11:10 AM
  #110
honki24's Avatar
Tell "them" to send E85 to south east VA......
Old May 1, 2007 | 09:39 AM
  #111
mplspilot's Avatar
whoever runs 1000 injectors, can you please post your scaling/latency?
my guess is these would need to be scaled to around 700 or so?
Old May 26, 2007 | 11:20 PM
  #112
EvoAnthony's Avatar
So I have 880 injectors scaled right now to 790's in ECUFlash. What would I scale them to if I converted to E85? Also if I converted to E85 am I still looking for the same A/F's as on 110 gas tuning wise (i.e. WOT 12.0-12.3a/f and 14.7 cruising a/f?)
Old May 27, 2007 | 05:30 AM
  #113
PVD04's Avatar
It'll take a little trial and error to figure out where to scale them. You could start around 500 and work from there.
The A/F ratios you listed would work fine on E85.
Old May 27, 2007 | 10:10 AM
  #114
mplspilot's Avatar
I think that's too lean. E-85 max rich/lean is earlier in lambda than that of gasoline. I would shoot for 11.1-11.5
Also for perspective my 1000cc are scaled to 609.
Old May 27, 2007 | 10:53 AM
  #115
MalibuJack's Avatar
This is the one confusing part about tuning E85 using a gasoline calibrated wideband
Old May 27, 2007 | 01:05 PM
  #116
http://www.e85mustangs.com/tuning.html
"If you already have a standard gasoline AFR meter hooked to a wideband O2 sensor, you can still use the displayed gasoline AFRs in determining your engine's true AFR. For example, if your gasoline meter is showing 14.7, then we know this is Lamda of 1.0. The equivelent on the E85 side is around 9.7. Therefore you can effectively use existing gasoline AFR components or software to tune an E85 evo without buying special equipment."
Old Jul 6, 2007 | 10:14 PM
  #117
Smogrunner's Avatar
Fantastic thread. Any updates? Anyone willing to share their fuel tables/maps on ECUflash with 1000cc injectors?
Old Jul 7, 2007 | 04:44 PM
  #118
PVD04's Avatar
I used the injector scaling to create an across the board adjustment and then did fine tuning from there. My fuel maps won't do you much good because I'm using the MaftPro to run speed density. I currently have my injectors scaled to 609 and the same latency I had with gasoline. Beyond that it's pretty much the same as tuning gasoline.
-Paul
Old Jul 16, 2007 | 07:27 AM
  #119
JrCRXHF's Avatar
Originally Posted by KevinD
no, turbo f4i is so big and heavy and doesn't make any more power then a non turbo f4i on 93. weight is the name of the game in formula sae. cost, complexity, reliability, weight are all worse when you turbo the 4fi. the f4i on 93 will already max out the restrictor, so if your drivers can shift theres no need for a wider power band.
our 06 car was super light with the 250 turbo. the car weighed 395 pounds without the wings, not using any titanium, and a steel tubeframe. and it made 73 hp (which generally the other sub 400 pound cars were all single cylinder cars making 40hp at best. with the wings and other last second bull**** it weighed 450lbs.
the 06 wings were much more effective then any other years, with the car being able to pull 1.8g's in a 200 ft skidpad. previous years were significantly slower.
the problem with the 250 is it is really unreliable and only myself and our engine lead had any idea what was going on with that engine package. dr. bob the self claimed "king of the world" at engine tuning had no idea what was going on, as shown by his poor showing of the 06 car at the texas autocross weekend. and yes, he was the one telling the team what to do, and the one tuning the car after california (also a week before california while i was at a friends wedding... thats why our engines all blew when i was gone, and thats why we never had a running car in cali... but thats another story)
but what he did not tell you is that a Turbo F4i well make more TQ and you have more area under the curve because the turbo well make the restrictor go sonic before a N/A motor well. So you have the same peak power but the turbo motor well have more usable power.
EvolutionRacing
Jan 18, 2016 09:55 AM
Jim in Tucson
E85 / Ethanol
49
Sep 2, 2010 01:41 PM
Ted B
Nov 22, 2008 05:52 PM
Smogrunner
E85 / Ethanol
21
Aug 3, 2008 09:05 AM
Kc2Buk
61
May 5, 2006 11:39 AM
