ECUFlash / Evoscan / Mitsulogger Questions
Old Nov 12, 2010 | 11:50 AM
  #871
raasfaas's Avatar
It sounds like you're running the Tephra mod...if its a newer version of ecuflash it should be under "Turbo boost single solenoid" as boost cut load.
Old Nov 13, 2010 | 07:41 AM
  #872
jasons9594's Avatar
Ya thats where i found it....now its time to go play with this thing....
THANKS
JASON
Old Nov 13, 2010 | 05:34 PM
  #873
joshesh's Avatar
I need some help, evoscan v2.6 isn't able to log my LC-1 wideband. I can get it to locate it, correct com port. Logworks is logging the LC-1 fine I just can't get the connection to log through evoscan, any ideas?
I also cant seem to get the fuel trims to log anything but 0.1 - I need some ideas for this issue as well.
Thanks
Old Nov 15, 2010 | 08:13 AM
  #874
jasons9594's Avatar
Thanks it worked perfect....
Old Nov 15, 2010 | 09:12 AM
  #875
raasfaas's Avatar
np, glad I could help
Old Nov 17, 2010 | 08:04 AM
  #876
deeman101's Avatar
Originally Posted by Mitsu.kid.02
its weird i have evoscan saved in two locations it seems. Im using windows XP pro BTW. The first directory is "C:\Program Files\EvoScan\EvoScan v2.7" The other one is "C:\Documents and Settings\Administrator\My Documents\EvoScan v2.7" Is this what you mean?
The program files one is where the actual program is installed and runs from. The My documents location is there for saving data logs and temporary files and stuff.
Old Nov 17, 2010 | 06:35 PM
  #877
kanyonkid's Avatar
Thanks
what baudrate are u using? 15625 or 62500?
Old Nov 17, 2010 | 06:38 PM
  #878
kanyonkid's Avatar
evoscan 2.6
baudrate 15625 timeout ms 1000
open port 1.3x
I have a similar problem but i have an AEM wideband serial>usb.
I can log the wide band external but it only reads it for about 5 secs then it stops and freezes on the last afr reading.. evoscan still works fine, only the "external wideband" section locks up.
does anyone one else have this issue?
Old Nov 24, 2010 | 06:56 AM
  #879
joshesh's Avatar
Originally Posted by kanyonkid
evoscan 2.6
open port 1.3x
Same Baudrate and timeout as you
same open port cable and v2.6 of evoscan.
I am giving up with the serial-usb signal... I'm going to put one of the analog outs into the ECU and log everything through evoscan.
Old Dec 7, 2010 | 07:18 PM
  #880
EVOMIZ's Avatar
Anyone have a pic of ecuscan gps unit in there evo 8?
I am getting tired of lugging my net book back and forth to the car, but wanted to see where people put them in the car. besides windshield mount
Old Dec 18, 2010 | 09:27 AM
  #881
06RedRalli's Avatar
Can anyone tell me why when I'm logging in EvoScan starting after my wideband....everything is off by one line???
It's causing me not to be able to graph the results.
Old Dec 18, 2010 | 09:49 AM
  #882
nothere's Avatar
I just pull the card, leaving the unit alone.
Old Dec 18, 2010 | 03:09 PM
  #883
deeman101's Avatar
Hey guys I'm having trouble with evoscan v2.8. Whenever I log it randomly times out and displays error 'fid' -4 or something similar (definitely -4 though). Same error I get when I try to log my ACD but I'm not sure I have the pins configured for that. I used to log like 7mb files with v2.7 but I remember it used to give me this probably too a couple months before I switched to v2.8. Help??
I'm using tactrix 1.3U and rom 9694011 btw.
Also does anybody else find the scaling on stock MDP to be way off? My evoscan log says 45psi at full boost. Should be more like 15....
Old Dec 18, 2010 | 04:13 PM
  #884
link62's Avatar
hey i need help trying to view my log files on windows 7 i have evoscan 2.5 and when i go to the folder where the logs should be at only the sample logs are there but when i use maptracer it shows my logs in that folder
also for some reason evoscan doesnt seem to want to log injector duty%
Old Dec 18, 2010 | 04:56 PM
  #885
raasfaas's Avatar
When you're logging injector duty cycle make sure injector pulse width is being logged also and it has to be before IDC in the list.
When you go to the map tracer and about to select your log, hit the "up one level" button and see exactly where evoscan is storing those logs. It's suppose to be in the saveddatalogs folder, but it might be located somewhere else.
