ECUFlash / Evoscan / Mitsulogger Questions
Old Mar 22, 2012 | 10:15 AM
  #1216
BonsaiScott's Avatar
Originally Posted by BonsaiScott
[14:05:45.341] EcuFlash Version 1.43.3252
[14:05:45.341] OS Version Windows 7
[14:05:45.341] Qt Version 4.6.2
[14:05:45.341] 62 memory models read.
[14:05:45.341] scanning for metadata models in C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata
[14:05:45.513] 356 ROM metadata models scanned.
[14:05:45.513] checksum module "subarudbw" loaded.
[14:05:45.513] checksum module "mitsucan" loaded.
[14:05:45.513] checksum module "mitsuh8" loaded.
[14:05:45.513] patch module "Subaru CAN Enhanced RAM Parameter Logging" loaded.
[14:05:45.513] patch module "Mitsu CAN RAM Parameter Logging" loaded.
[14:05:45.513] flashing tool "wrx02" loaded.
[14:05:45.513] flashing tool "wrx04" loaded.
[14:05:45.513] flashing tool "sti04" loaded.
[14:05:45.513] flashing tool "sti05" loaded.
[14:05:45.513] flashing tool "mitsukernel" loaded.
[14:05:45.513] flashing tool "mitsukernelocp" loaded.
[14:05:45.513] flashing tool "mitsubootloader" loaded.
[14:05:45.513] flashing tool "shbootmode" loaded.
[14:05:45.513] flashing tool "shaudmode" loaded.
[14:05:45.513] flashing tool "subarucan" loaded.
[14:05:45.513] flashing tool "subarucand" loaded.
[14:05:45.513] flashing tool "mitsucan" loaded.
[14:05:57.695] Using interface OpenPort 1.3 Mitsubishi EVOSCAN1d468f6d500000000000000000000000000000000
[14:05:57.695] interface close
[14:05:57.710] unable to connect to vehicle interface.
EvoScan 2.9 works fine, but I had to change to MUTIII & set the baud rate to 62500. Searched for but can't find a way or need to set the same under ECUFlash. ECU is not locked. I can use EVOScan to read/verify ECU flash. Win7 control panel says 1.3 cable is working fine. Tried re-installing ECUFlash to no avail. Any suggestions?
I'm stumped. I've tried the 1.29 driver for the 1.3 cable, 1.29 ECUFlash, disabling the serial port driver, all to no avail. I've verified the battery voltage, tried with the car running and off, and verified the wiring of pin 26 to pin 79. If ECUFlash is open and I plug and unplug the serial cale for the 1.3 cable, it correctly detects its presence or absence with the notice in the lower right.
EVOScan reads the ROM and can verify the read file matches the contents of the ROM. However, that's only with the baud rate set at 62500 (I modified the ECU's rate to 62500 for faster logging and it works great). If I set the baud rate to anything other than 62500, EVOScan fails to read the ROM. This leads me to believe that I need to change the baud rate within ECUFlash. However, I cannot find any way to do that.
Is there a way to change ECUFlash's communication baud rate? I tried the serial shadow of the driver in the control panel, but there's no match to 62500. I set it to the closest value (57xxx) but as expected, that didn't help.
Old Mar 31, 2012 | 04:50 PM
  #1217
06Black's Avatar
Is there a trick to getting EvoScan 2.9 to read DTC's?
It seems like it works on all my friends laptops, but every time i try it i just get a ECU communication error. (not exactly sure what is says of the top of my head)
when using EvoScan, in the "items to data log" list, if i click on the "clear EFI diagnostic codes" it will clear the code, but i cant display it to actually see what the issue is.
Ive got a Dell E6410 on Windows XP.
what in the crap am i doing wrong?
Old Apr 1, 2012 | 09:03 AM
  #1218
nousername's Avatar
Try scan tech for DTC's that's what I've just had to do.
Is there any date for a 2.9.0020 version with the injector scaling fix? Need to log load.
Old Apr 1, 2012 | 10:04 AM
  #1219
domyz's Avatar
ECUFLASH:
I don't know how to delete a wrong table that I created, I was trying to relocate one but I instead created another and I cannot remove it.
Is there a way to delete a map/table?
Old Apr 10, 2012 | 08:08 PM
  #1220
SLO-EVO's Avatar
I can't choose the car model. Any suggestions?
Old Apr 13, 2012 | 09:31 AM
  #1221
evoracingstar's Avatar
any one got a link where i can download a program just to log my car. i used mitsulogger like 3-4 years ago now i cant find a link to download it. please help that be great thanks alot!!
Old Apr 16, 2012 | 09:27 AM
  #1222
schreckus's Avatar
hey guys, can anybody tell me the pinning of the evoscan 1.3r cable? a buddy ripped up the 5 cables from the obd plug to the pcb:-/
greetings schreckus
Old Apr 17, 2012 | 01:08 AM
  #1223
Harismr8's Avatar
any one got a link where i can download a program just to log my car. i used mitsulogger like 3-4 years ago now i cant find a link to download it. please help that be great thanks alot!!try evoscan.org
Old Apr 17, 2012 | 11:13 AM
  #1224
itospeedz1's Avatar
Whats up every one? i'm a little new to the evo. i'm trying to get my friends car to pass inspection the vehicle is an 04 evo rs with a 96420008 rom and i can't find any info. i saw a video on you tube were someone has edited the rom to access obd address in rom. any help would be appreciated. can i use any other rom def on this ecu?
Old Apr 18, 2012 | 07:40 AM
  #1225
MR.EVO00's Avatar
Access port for sale
Gear power adder for basic boltons selling for low price I personally went 12.50 with but have serious mods now an time to sell it $300
Old Apr 18, 2012 | 02:59 PM
  #1226
MR.EVO00's Avatar
Good*
Old May 2, 2012 | 09:21 PM
  #1227
blknblubkrdude's Avatar
Hello, I just began the process of remote tuning.
I sent my current ROM off, and just got a bin file base map tune for speed density back.
When I go to open it in ECUFlash I get an error stating: "Unknown ROM Image"
What is there I can do?
Along with the base map, I also recieved the Tephra V7 mod (xml file). I placed it exactly where instructed to.
My question is, do I have to modify something to do with the TephraMod before ECUFlash will accept the SD base map?
Thanks for any help!
Old May 3, 2012 | 01:07 PM
  #1228
evoscan's Avatar
Silver Sponsor
you can download the missing xml files from www.evoscan.com/roms/mitsubishi and place them in the ecuflash folder. then it will work.
Old May 4, 2012 | 01:39 PM
  #1229
Scofflaw's Avatar
Hey everyone, I'm getting really frustrated here. I'm trying to scan my DTC codes. I have a tactrix 2.0 cable, the latest evoscan/ecuflash, 2004 Evo RS. I tried to fiddle with the settings, but I always get "No response from vehicle ECU". Last time I tried to fiddle with it, I hit "clear DTCs" to see if that worked, and it did. I also tried scantech, and it won't even initialize.
Info: OpenPort 2.0 Found.
Info: OpenPort Firmware v1.11.329
Info: Battery 12.286V
Info: Initialize Vehicle ECU...
Info: OBDII Connecting...
Info: Initializing At 5 baud...
Info: Initialization Complete...
Info: Waiting for vehicle ecu...
Info: Connecting...
Info: Battery 12.308V
Info: No Response from Vehicle ECU
Info: Check DTCs Complete.
My original problem is that I had a rough idle. It would go full lean and sound like it's about to stall, then rev up to 1200rpm and go full rich, and bounce back and forth.
Anyways, any help would be appreciated.
Attached Thumbnails ECUFlash / Evoscan / Mitsulogger Questions-evoscan.png
Old May 6, 2012 | 02:12 PM
  #1230
Scofflaw's Avatar
Little update from above. Did a boost leak check, and found all kinds of leaks. I was procrastinating about doing it, but now wish I did it earlier. Anyways, fixed those leaks, and I found when I set evoscan to MUTIII, everything work except for DTCs. I just can't read those with any program so far it seems. I tried a generic handheld reader, and it just displays "ERROR".
