ECUFlash / Evoscan / Mitsulogger Questions
ok so my previous laptop crashed and i lost everything including my roms, evoscan, all the data logs etc..i need to start fresh.
so i had the tephra v7 installed in my evo 8, before the laptop crashed...
i installed ecuflash version 1.42, read from my cars ecu and it says UNKNOWN ROM IMAGE...so what do i need to do now for ecuflash to read my cars ecu?
I installed evoscan and ecuflash. I was able to flash the car however when starting Ecuflash it states error loading FTD2xx.DLL. Also, when I try to datalog on evoscan it says that FTDI USB driver are not installed.
It said to look for ftD2XX.DLL in windows/system32 folder. I was unable to locate the ftd2xx.dll there.
Suggestions?
Suggestions?
You can copy the dll from the Ecuflash folder and paste it in the Windows Sytem32 folder.
Find it here; C:/Programfiles/OpenECU/EcuFlash/drivers/openport 1.3/i386
If you have Windows7 it will be in the Programfiles(x86) directory.
If using Windows7 you will also need to copy the dll into the C:/Windows/sysWOW64 folder
Will this type of cable work for datalogging?
I got it and I am having some problems. Getting: Error: OpenPort2 USB Cable Not Responding.
I have tried installing the Latest 2.9 Evoscan along with ECUFlash 1.42
I have tried several combinations of 2.9, 2.7 Evoscan and ECUFlash 1.42 or 1.43 in different orders and I get the same error message.
The PC does detect the cable and I am able to select the driver to install as the one that gets installed with ECUFlash each time.
http://www.amazon.com/gp/product/B005WGIN5G/
If you bought the blue tooth OBD2 scan tool it should have it's own software.
As far as I know you would need the Openport to have Evoscan and/or Ecuflash work. I could be wrong though, have no experience with anything other than openport.
Can someone post a link of an openport cable that is confirmed to be working? I am not looking to reflash or make any changes. Just do simple data logging for now.
Boosting 1 bar only....waste gate pressure.
My tuner tried tuning my car yesterday after I installed a GReddy O2 Housing,and it's only boosting 1 bar.Even on the high boost map.Boost only comes in at 4000 rpm.
Things we have checked so far:
1. Turbo waste gate is closed.
2. Boost controller is not faulty.
3. BOV is fine.
I can only think it could be a major bost leak,I will have it tested tomorrow.
If It's not that then I don't know...need help urgently.
Not sure If i posted this in the right section.
3. BOV is fine.
That's the whole housing.We tried another boost cotroller and re-connected mine back up correctly.
When i left the shop today the car was smoking white smoke.I guess the turbo is gone....
