EvoScan and check engine lights
Old Jan 3, 2007 | 01:13 PM
2JZfan's Avatar
A few days after doing my TBE (catless), MBC, fuel pump and eflash I got a check engine light. I figured it was the o2 sensor code because of not having a cat. Today (about a week later) I finally used EvoScan to pull the codes but it didn't find any. I tried like 10 times and about half of the times it would get an error (timeout errors some of the times, other times it said something like "cable not responding"). Other times it wouldn't get an error it would just say "no DTCs found". Hitting the button to clear the codes was hit or miss too, sometimes it would produce those same errors, sometimes it wouldn't do anything. Anyway, the bottom line is I never got a code and I still have the check engine light on. I have the tactrix cable and I have never had any other problems using EcuFlash or doing normal logging through EvoScan. Is there a better software package for checking/clearing codes?
Thanks!
Old Jan 3, 2007 | 01:25 PM
dryad001's Avatar
Evoscan isnt set-up for the engine codes yet.
Old Jan 3, 2007 | 01:31 PM
BADEVO's Avatar
Thanks!
Autozone or Advance Auto work like a champ. LOL
Actually if you look in the ECU Flash section of the forum I believe there is a software that is available to check and clear codes. Malibu Jack has one as well I believe.
Old Jan 3, 2007 | 01:39 PM
bvdawg13's Avatar
evo scan wont detect your check engine...go here http://www.aktivematrix.com/forum/ and download the OBD scan tech after registering
Old Jan 3, 2007 | 02:45 PM
2JZfan's Avatar
ok, thanks guys. I assumed that the Check/Clear DTC buttons in EvoScan might actually do something, stupid me!
Old Jan 3, 2007 | 03:23 PM
3gturbo's Avatar
He's working on it actually so it will in the future.
Old Jan 3, 2007 | 03:29 PM
kreionic's Avatar
yeah the evoscan dtc is terriable. Do what they said go to malibujacks page and get his generic scan tool works great
Old Jan 3, 2007 | 10:31 PM
evo4mad's Avatar
EvoScan DTCs works perfectly for the Evo IV/V/VI, and pre '98 mitsubishis, it just doesn't work for the US evos. Use any generic obdII scantool that supports direct passthrough (jeffs serial converter) like scantech.
Old Mar 20, 2007 | 03:30 PM
rallykid's Avatar
Can you prevent codes from returning, like the (no cat) cel?
Old Mar 20, 2007 | 03:33 PM
inco9nito99's Avatar
Wierd, even with my $5 CEL eliminator I'm still throwing a CEL for the o2 sensor.
hearnoevo
Oct 14, 2016 09:15 PM
Smalls
Aug 9, 2014 02:38 PM
Indianbrandon
Dec 28, 2012 01:20 AM
fireroasted
Dec 15, 2011 02:24 PM
SmurfZilla
E85 / Ethanol
Oct 26, 2009 05:35 PM
