EvoScan v0.98 Now with Power & Torque Graphing - Map Tracing completed also!
Old Mar 5, 2007 | 12:01 PM
  #286
C6C6CH3vo's Avatar
Originally Posted by laakness
Evo4Mad, not sure if you've seen this or is a noted bug but I can't play back log files with .98 while guages are turned on.
If I just turn on an RPM guage and set it to data item "Engine Speed" the error comes up.
Error message: Column '21' does not belong to table LogData
Similar errors come up only with different column numbers for different items.
Laarkness, how did you get the guages to work? A knock sum counter, knock indicator and a loud warning is the sole reason I will be using the v0.98 but I cant get them to allow the program to run
Old Mar 5, 2007 | 02:20 PM
  #287
cfdfireman1's Avatar
you are correct sir.
Originally Posted by iTune
first off, I never used the word explosion.... if you mis read one of my posts, I can understand why the word explosion would scare you...but I never used the word explosion.
also, I don't need a wikipedia explanation of what pre-ignition and detonation is. I know all about this topic, just search my name. your not dealing with a novice here.
wow, we are way off topic now. lets not beat the dead horse, shall we?
CJ
My apologies I will practice my reading skills.
Old Mar 5, 2007 | 02:29 PM
  #288
iTune's Avatar
No problem!
i aint mad at ya!
I too am having trouble using the gauges...also, i have not found a way to label the guages and i typically like to have a lot of indicators up so i can see all the most important info. I'm i missing something?
CJ
Old Mar 5, 2007 | 02:30 PM
  #289
laakness's Avatar
The gauges worked for me right away but aren't working during playback. I don't know if they are actively working while logging. I haven't tried.
Old Mar 5, 2007 | 04:32 PM
  #290
Evo9tunerz's Avatar
Okay i'm new to evoscan.. does someone have a tutorial to evoscan? or an easy way to learn how to use all the options?
Old Mar 5, 2007 | 04:49 PM
  #291
jibbed's Avatar
I'm having the Column 21 error too when trying to play back.
I'll just stick with 0.97 until the final 0.98 version is released.
Cheers,
matt
Old Mar 5, 2007 | 06:37 PM
  #292
C6C6CH3vo's Avatar
Cheers,
matt
You mean this isn't the final 0.98 version?
Hell, what am I worried about
Old Mar 5, 2007 | 06:39 PM
  #293
C6C6CH3vo's Avatar
Are you getting the knock alarm to sound when you get a trigger?
I have my own .wav file ready once I get it to work - it says "lift throttle, your knocking idiot!!"
Old Mar 5, 2007 | 07:57 PM
  #294
iTune's Avatar
oh yeah, meant to ask......what do you do to make the power/torque calculations work??
CJ
Old Mar 5, 2007 | 08:22 PM
  #295
jibbed's Avatar
Nahh - Not according to Evomad - he's still working out the final bugs. When he's released the full version, he'll update his site accordingly.
Cheers,
matt
Old Mar 5, 2007 | 08:48 PM
  #296
laakness's Avatar
Haha, that's awesome. I know there is bugs in those areas so I didn't really go test it.
The power graphing looks like it has Data Log Lab embedded in it. To calculate the horse power correctly you should try to just have a log with rpm to redline and that's it.
I modified my log file so that it only had the full pull in it with no decel.
Old Mar 5, 2007 | 08:56 PM
  #297
iTune's Avatar
i tried that, but it said i had 785WHP....lol, i has all the settings correct too...lol
CJ
Old Mar 5, 2007 | 09:13 PM
  #298
laakness's Avatar
you should send me your log, I can throw it in data log lab the full version
Old Mar 6, 2007 | 06:20 AM
  #299
Ted B's Avatar
CJ
Wow, impressive!
Old Mar 6, 2007 | 06:38 AM
  #300
jfitzpat's Avatar
CJ
Have you trimmed your log to just a 3rd gear pull? I know we give bloated results if you don't highlight the proper section of the log. It has to do with the calculation of slope.
-jjf
