log boost with JDM MAP sensor (updated instructions)
Old Mar 3, 2009 | 11:21 AM
  #601
raasfaas's Avatar
Quick question, I just got my map sensor and am in the process of doing the rom changes (88590015). At the last section where it says to disable the EGR test you need to change ECU Periphery2 from EFDF to EDDF...but when I open my periphery2 it shows 0001 instead of EFDF...everything else shows up like the instruction says so I just want to be sure this is ok before I move on.
Thanks.
Old Mar 3, 2009 | 12:46 PM
  #602
Appauldd's Avatar
Thanks.
That was the older way of disabeling the EGR test. Now it is done by changing the Periphery bit FCA bit 9 to 0, and also FAA bit 11 to 1 to disable the EGR completly.
Old Mar 3, 2009 | 01:13 PM
  #603
raasfaas's Avatar
Oh ok, I guess I haven't gotten to that part yet...need to do a search to find those periphery tables.
So when I do it that way would I just leave the value that's in the periphery2 as is?
Old Mar 5, 2009 | 09:21 AM
  #604
fostytou's Avatar
EvoM Community Team
The value in periphery 2 (which is the FCA bits) will change when you change the FCA bit 9 via blobbits. It will change the 0xXXXX hex value because they are pointing to the same thing, just displaying it in a different way.
I personally would not completely disable the EGR via FAA bit 11 as applaud suggested, but that is my personal preference. If things are working fine with the EGR enabled then it may be OK to just leave it.
Note that disabling the EGR test will prevent any CELs, but may not pass emissions testing if that is an issue for you. If you have to do emissions testing you may want to leave it enabled and just clear the code when it comes up (or apply the new patch to "fool" the system).
Old Mar 5, 2009 | 09:27 AM
  #605
Appauldd's Avatar
I have found no ill effects from disabling the EGR the way that was suggested. But then again, no emission testing in my state, and my egr is blocked off any how.
Old Mar 5, 2009 | 09:40 AM
  #606
raasfaas's Avatar
well here in Jamaica we don't have any emissions tests...so if changing the FAA bit 11 to 1 totally disables the EGR then what does changine the FCA bit 9 to 0 do?
Appauldd - even though you said its the old way, but would I need to get all these periphery tables defined if I just want to disable the test, or can I just do it from changing periphery2 to EDDF?
Old Mar 5, 2009 | 09:53 AM
  #607
RoadSpike's Avatar
Edit:
I was totally off on the bits n/m
Old Mar 5, 2009 | 09:54 AM
  #608
Appauldd's Avatar
The EGR TEST can be disabled with FAA bit 11 changing it from 0 to 1.
The EGR operation will be disabled with FCA bit 9 changed from 1 to 0.
Old Mar 5, 2009 | 09:55 AM
  #609
Appauldd's Avatar
Originally Posted by RoadSpike
Thats incorrect setting the bit to 0 disables it not 1.
bit 11 is the EGR
bit 9 is the cold start retard
Cold start retard????? This isn't want was posted in other conversations.
Now I am getting confused....UGH
Old Mar 5, 2009 | 09:57 AM
  #610
RoadSpike's Avatar
Really?
I thought a setting of 0 disabled the routines. Tephra said that bit 9 was the cold start retard though or was that found to be different?
  #611
RoadSpike's Avatar
This is where i got the bit 9 info
https://www.evolutionm.net/forums/ec...your-maps.html
EDIT:
Oh i totally understand what your saying now. I'm talking about the FAA bits and your talking about the FCA bits.
https://www.evolutionm.net/forums/at...t_20080830.pdf
Old Mar 5, 2009 | 10:23 AM
  #612
Appauldd's Avatar
Originally Posted by mrfred
As Mr Turco said, setting FCA bit9 = 0 will disable the EGR OBD-II test, and it will show up as "Not Supported" on an OBD scanner. As far as I know, "Not Supported" is a perfectly acceptable (while "Not Complete" or "Not Ready" is unacceptable). If you run a scanner on your car now, you'll see that there are several tests that are "Not Supported" with a completely stock ROM.
Yep, it will do this without having to touch the EGR valve.
OK so I am all screwed up now....Sorry for any confusion I may have caused.
This is what my notes say....
FCA Bit 9 to 0 = Disable EGR Test
FAA Bit 11 to 1 = Disable EGR
I havn't noticed the cold start 2000 RPM issue.
So I guess others have discovered that FCA bit 9 is for cold start....Got it. I will make the chages to my ROM. Thank you for clarifying.
Old Mar 5, 2009 | 10:25 AM
  #613
Appauldd's Avatar
Originally Posted by 03whitegsr
I disabled FAA bit 11 (set to 1), FCA bit 9 and set all the EGR related tables to zero, including high/low octane EGR enabled advance, Base EGR duty, Secondary EGR duty, EGR coolant temp correction, Alternate EGR Duty.
Drivability off idle was unchanged but idle was terribly rough.
So now we need to figure out what the answer is.
I am so confused.
Old Mar 5, 2009 | 10:30 AM
  #614
RoadSpike's Avatar
No no you had it right I'm the one on cold meds here
I didn't see the mention of FCA bits and mistakenly assumed you guys were talking about the FAA bits. I think i should just take a rest today .
Old Mar 6, 2009 | 05:36 PM
  #615
wreckleford's Avatar
Thanks.
If your car is JDM the periphery bits will likely be different. The EGR may be non existent. Are you sure you are using 88590015?
