need help with ECUFLASH
Old Apr 13, 2007 | 01:05 PM
supersnow's Avatar
I read the image from my ecu with no problems but when I try to open any map within the ROM it says the following "The current map description is invalid or incomplete. Please edit the map description to fix the problem and the map will be viewable again". Any pointers.
thanks
Old Apr 13, 2007 | 01:27 PM
supersnow's Avatar
bump!
Old Apr 13, 2007 | 01:36 PM
tcarretti's Avatar
did you save it with the .hex file suffix?
If not, simply rename the file xxx.hex and you should be able to open it up.
Hope that helps,
Tony
tcarretti's Avatar
Sorry, disregard....
Didn't notice that you were already able to open the ROM...my bad....
do you have the right definition files loaded in Ecuflash?
Old Apr 13, 2007 | 01:38 PM
supersnow's Avatar
what you mean by right definitions files?
Old Apr 13, 2007 | 01:39 PM
supersnow's Avatar
The only parts of the rom that I can open is the init code and immobilizer
Old Apr 13, 2007 | 01:42 PM
supersnow's Avatar
In the rom data portion, ecu id, case id and checksum module are blank, the internal id was fill auomatically
tcarretti's Avatar
There is a folder in the EcuFlash folder that is called metaromdata or something. It contains .xml files with definitions for the different Evos. You need to have the correct xml file for your car in there or you will be unable to see some or all of the maps on your downloaded ROM.
Old Apr 13, 2007 | 01:45 PM
supersnow's Avatar
there is one xml file with the same name as my internal id 9694011, I though that ID is unique to each ecu
Old Apr 13, 2007 | 02:04 PM
supersnow's Avatar
My car was flash last year with buschur stage 1(dynoflash).......so there is a possibility that my rom id is alter or locked, I download ecu unlocker but i get an error while reading the image from the ecu
Old Apr 13, 2007 | 02:54 PM
supersnow's Avatar
if somebody could be kind enough to provide me with his email so I can send my map and see if it can be figured out, as far as I know I have all the xlm definition for my rom.
thanks
Chris
Old Apr 14, 2007 | 07:08 AM
burgers22's Avatar
Hi
Looks like the ID got changed to confuse anyone trying to read it. Do a search on here for scrambled maps. Malibujack has several very good posts about how to solve this issue.
MB
nazzal
Oct 9, 2023 08:18 PM
thndrballl
Lancer Engine Management / Tuning Forums
Dec 31, 2015 01:15 PM
Stradale
Oct 21, 2011 11:04 PM
turbotsi
Oct 13, 2011 09:08 AM
evo1981
Nov 10, 2010 06:44 PM
