What a difference....
Old Jun 4, 2007 | 10:45 AM
nj1266's Avatar
Thumbs up What a difference....
Yesterday I installed the TBE that I had on my 8. It is a JIC dp, an Invidia N1 exhaust and a HFC. I love this set-up because it is quiet, light, and makes power.
I also extended the lean spool from 7000 rpm to cutoff. Thanks mrfred Then I went logging. I was amazed at the difference that the TBE and the lean spool made to the car. When I logged the car prior to this, the car would fall flat on its face after 7000 rpm due to disabling of the lean spool system. After extending the lean spool, this no longer happens and the car pulls like a freight train all the way to cutoff.
The AFR also leaned out to such an extent that only minor adjustments are now needed to hit 11:1 AFR.
The boost also improved and held better to redline than before. Again, only minor adjustments are now needed. Keep in mind that I run on 91 octane fuel and cannot run a lot of boost like the 93 octane folks.
Here is some data to share with you. The data is based on three logs stock and three logs with TBE and LS extension:
AFR stock:
AFR with TBE and lean spool extension:
Boost stock:
Boost with TBE and LS extension:
Attached Thumbnails What a difference....-my9_afr_stock.gif   What a difference....-my9_afr_tbe.gif   What a difference....-my9_boost_stock.gif   What a difference....-my9_boost_tbe.gif
Old Jun 4, 2007 | 10:46 AM
nj1266's Avatar
And for the grand finale, the power gain. The car gained 24 hp on DLL and 7 ft-lb of torque and that is w/o any real tuning. OK, you can call the LS extension tuning if you want. Notice how the hp curve holds almost steady all the way to cutoff while before the curve fell after about 6500 rpm. This is, in part, due to the stupid lean spool disable @ 7000 rpm.
Old Jun 4, 2007 | 10:52 AM
dudical26's Avatar
what program is that, that shows you where in the map you are.
Old Jun 4, 2007 | 10:54 AM
nj1266's Avatar
It is Logworks...As they say Innovate FTMFW
Old Jun 4, 2007 | 11:47 AM
jcsbanks's Avatar
Nice.
Now how about adding:
JDM RS MIVEC map
+30 on the boost limit
+50 on the boost control load offset (this should make it just run 100% on your single solenoid, which will probably give about the right boost on your rodent urine 91 octane?)
That lot would make it richer again
Worth comparing the baro reading at cruise and then at 7000 RPM. Big restriction there.
Old Jun 4, 2007 | 12:53 PM
juyanith's Avatar
Where exactly is the sensor that the "baro" column is coming from? In the MAF housing?
Old Jun 4, 2007 | 01:22 PM
jcsbanks's Avatar
Yes, it is like being at 2500ft elevation on the standard airbox at high revs.
Old Jun 4, 2007 | 01:31 PM
chmodlf's Avatar
Which HFC are you using?
Old Jun 4, 2007 | 02:26 PM
laakness's Avatar
That's for damn sure!
Old Jun 4, 2007 | 02:34 PM
mrfred's Avatar
Originally Posted by jcsbanks
Nice.
JDM RS MIVEC map
Should be able to run with out knock at 22.5 psi.
Old Jun 4, 2007 | 04:59 PM
nj1266's Avatar
An Ultimate Racing HFC.
Old Jun 4, 2007 | 09:00 PM
occultworks's Avatar
Okay, I feel dumb now. Where's this lean spool at in ecuflash? Is it the boost enhancement start and stop rpm parameters? I'm still pretty new to this stuff, so please be kind.
Old Jun 4, 2007 | 10:19 PM
codgi's Avatar
Same one I've had the last year or so....runs like a champ and not too expensive either .
I just increased my lean spool disable to 7500 on mine for more testing this week but the dyno at the end of the week will tell all...
Old Jun 4, 2007 | 10:25 PM
codgi's Avatar
You have to make a modification ECUFlash to get it to show this parameter. It is a rom specific modification. See this thread:
https://www.evolutionm.net/forums/sh...ight=byte+load
They are a few others floating around as well. I would suggest backing up your ECUFlash xml files (and original rom) before messing around with them though .
Old Jun 4, 2007 | 11:19 PM
nj1266's Avatar
Nice.
JDM RS MIVEC map
Is this the right JDM RS mivec map. There are a lot of them floating around. I just want to make sure that this is the right one
