calc HP/TQ from EvoScan using Excel
Old May 15, 2009 | 11:06 AM
  #76
nonschlont's Avatar
The #'s Im seeing are extremely close, if not spot on. Did you check the vehicle weight, as this would be important, also the baromic press., as Im sure you know... I changed my vehicle weight to 3500 (w/ driver/sub box) and my baromic press. to 30.12 as in my area.
My only gripe, but not really, is its showing peak TQ, 4-500 rpms late. I hit full boost/TQ @ 3500...
I would like to thank mrfred and JOT once again, for creating, and sharing an awesome tool to show comprisons from our pulls.
Old May 15, 2009 | 11:09 AM
  #77
rolly1818's Avatar
Registered User
The #'s Im seeing are extremely close, if not spot on. Did you check the vehicle weight, as this would be important, also the baromic level, as Im sure you know... I changed my vehicle weight to 3500 (w/ driver/sub box) and my baromic level to 30.12 as in my area.
cool i guess i will play with the settings and see. i am reading a lot higher that what i dynoed @ but since i retuned so many bloody times lol..... i may actually be faster
same problem here with peak TQ.
Old May 15, 2009 | 12:18 PM
  #78
Jack_of_Trades's Avatar
Here are the RPM/MPH values for 3rd and 4th gears guys:
5 speed
3rd = 84.63
4th = 62.01
6 speed
3rd = 87.28
4th = 66.95
Here is a good website to save on your cell phone or laptop to check your local temps and barometric pressure:
http://xhtml.weather.com/xhtml/cc/02893
In the upper right hand corner of the webpage you can change the location to your local zip code, then save the new link. It works well on iPod Touch/iPhone/Cell phone browsers so you can check your conditions while datalogging
As far as vehicle weight with only the driver included, most cars are between 3300-3500 lbs so if you are unsure you can just go somewhere in the middle at 3400 lbs. The difference between 3300-3400 lbs is about 3% so you wont be WAYYY off base. The key is to keep the weight the same between your comparison runs to see if your changes actually made gains. I use it mostly to tune for a nice smooth power curve, not just the hp/tq #'s.
I'm not sure whats up with the peak torque values being different when compared to actual dyno graph results...that would be Mrfred's realm since he did all the hard work with the math for that part of the spreadsheet.
Old May 15, 2009 | 01:54 PM
  #79
mrfred's Avatar
[QUOTE=Jack_of_Trades;7064745...
I'm not sure whats up with the peak torque values being different when compared to actual dyno graph results...that would be Mrfred's realm since he did all the hard work with the math for that part of the spreadsheet.[/QUOTE]
The formula in the Excel file calculates HP from the speed and elapsed time (acceleration). Torque is then calculated from the standard equation TQ = HP*5252/RPM. A Dynojet works on the same principle, but instead of accelerating the car, it accelerates a set of 2700 lb rollers. A Mustang Dyno works on a slightly different method. It uses both interia and power absorption to provide resistance to acceleration.
Anyhow, I do smooth the data, and the smoothing factor is setup to work best with a minimum of 60 lines of data in the run. If there are fewer than 60 lines, the smoothing will pull down the peak HP and TQ values slightly. Log only what you need for the run (I log less than 10 parameters, note that 2-byte values count as 2 parameters being logged), disable multithreading, disable logging to screen, and enable "Logger Superspeed".
Old May 15, 2009 | 07:11 PM
  #80
What is multi-threading anyhow?
Old May 15, 2009 | 11:17 PM
  #81
tephra's Avatar
multithreading in evoscan is there to speed up the GUI.
UNFORTUNALTYE it also slows down logging.. hence the reason to disable it
Old May 16, 2009 | 12:58 AM
  #82
rolly1818's Avatar
Registered User
6 speed
3rd = 87.28
4th = 66.95
knew it was more than 84 ... thanks!
how do i disable it?
Old May 16, 2009 | 03:25 AM
  #83
tephra's Avatar
in the menu
Old May 16, 2009 | 09:03 AM
  #84
I am currently editing the spreadsheet so all you have to do is check off a check box for the gear you are using depending on your transmission type (5 or 6 speed). I'll post up an example very soon
Old May 16, 2009 | 10:09 AM
  #85
Ok guys, give this a try for me. Next I'm going to move all of the boring calculation columns to the farr right and have all of the editable tables for "Gear Selection","Vehicle Weight", "Dyno Correction Factor" and "SAE Weather Corrections" right next to columns A & B so all of the pertinent info is all on the main page so new users dont get confused.
Attached Thumbnails calc HP/TQ from EvoScan using Excel-gear.jpg   calc HP/TQ from EvoScan using Excel-graph.jpg
Old May 16, 2009 | 10:24 AM
  #86
l2r99gst's Avatar
Looks great, except that you have a couple reference errors on the right showing the comparison hp, tq, and RPM. Make sure those are reference the correct sheet.
It should read:
Comparison Pull
397 WHP @ 6754 RPM
348 WTQ @ 4857 RPM
Old May 16, 2009 | 10:28 AM
  #87
Fixed. noticed after I loaded the image lol.
Old May 16, 2009 | 10:38 AM
  #88
l2r99gst's Avatar
I might use this today using DMA logging for a comparison of before and after my IC and LICP install. Also, maybe with and without cutout open/closed. Should be interesting.
Old May 16, 2009 | 10:51 AM
  #89
mrfred's Avatar
Definitely do a before/after comparison if you have time. Would be great if you could do IC before/after separate from the LICP.
Old May 16, 2009 | 11:05 AM
  #90
Yeah I was thinking of doing that with my zeitronix boost gauge as well since I now have the JDM map sensor installed I can log pre-and-post FMIC PSI
