calc HP/TQ from EvoScan using Excel
Well, Buschur said he'll gladly give us a datalog of his "Project White" stock ECU Evo when he has a chance to throw it on the dyno again when business slows down so he has some free time
So now we'll have data from 2 of the most widely used mustang dyno's on this forum. Cant complain about that!
I'm still trying to figure out why the peak torque doesn't match up though. The torque formula is correct which means the HP values are incorrect at least down in the low RPM range because it seems to be pretty darn close in the upper RPM range. Hmm.
It would be interesting to do a log with 2-byte RPM to compare. Maybe I can try it over the next few days, or this weekend, when I have time, since I have the live mapping and a MUT table in RAM that I can change readily to log different things.
Graphs may be different, but I think the idea is to adjust the formula so the peak HP and torque will be as close as possible to the real dyno.
I suggest a check off box for both the Dyno Jet and the Mustang, each using the appropriate formula of course.
The ideal scenario would be to do a dyno run then immediately do the same on the road. The spreadsheet formula could then be adjusted to match the dyno graph. Evoscan data from the dyno run would be irrelevant to the issue.
Good idea about the checkbox.
I'm not certain on Mustang dyno's (never looked into how they work), but with a dynojet, you can use the logs from the dyno. Instead of using the weight of the car, you use the weight of the rollers or weight being turned.
https://www.evolutionm.net/forums/ev...reet-load.html
https://www.evolutionm.net/forums/5622945-post91.html
Not if the dyno is setup correctly:
Mustang dyno load = street load?
A street run to double check the numbers is the best way to do it.
Of course you cannot simulate different wind speeds and direction on different times of the day.
Those are overlays of dyno vs street.
Anyway, I agree doing both is the best.
I got this from another thread:
Another thing that would be very intetresing is to run a log through DLL an then run the same log through the Excel Dyno to compare results (peaks and plot graphs).
As a rule of thumb you can't use dyno pulls in DLL as DLL's calculation is based around the rate of acceleration of the car in the real world, as recorded via RPM and translated to speed through the gearbox, diff and tire specifications. The rate of acceleration on a dyno does not match the real world for a given gear - it could be faster or slower, which would put the DLL calcs out.
But the rate of acceleration on a mustang dyno IS the same as the real world, if you weren't follow the posts above. Also, the Dynojet Correction Factor already counteracts the drag coefficient difference between a street pull and a dynojet pull. We will be able to get the simulator in the "ballpark" at least with a Mustang Dyno since its basically the same results as a street pull. I'm pretty sure it just measures RPM,time and acceleration...all of which we can simulate fairly close with datalogging and formula's.
we're not trying to make this thing EXACT guys, dont look too deep into this. We're just trying to get it as close as we can with the resources we have to minimize REAL dyno tuning time.
Also, I just did a pull while logging 1 byte RPM and 2 byte RPM with ZERO difference in the results.....other than the 2 byte RPM spiked its signal during one of the pulls and TOTALLY threw the readings out of whack. The clean 2 byte RPM run was exactly the same as the 1 byte run though.
MrFred, would you be able to post up a breakdown of the HP formula's you used and the source (if possible) so we can double check the spreadsheet formulas just to eliminate the possibility of a formula error?
Hmmm...thanks for trying. I have a few equations from LogWorks, DSMlink, etc, for TQ and HP calculations as well that I can compare if need be. I'm sure mrfred used a pretty good formula though and looking at his, it is doing the same thing for finding the peak, which is basically the point of greatest slope of RPM.
The peak torque issue has to be something with the way we are recording the data and some limitation thereof. I plan on tuning my car this weekend, so maybe I can throw some data in from DMA logs and see what I can come up with.
