No MAF? No problem!
Old Oct 9, 2007 | 03:56 PM
  #121
trinydex's Avatar
is there a diff between the "stock" 3 bar and the jdm map sensors?
Old Oct 10, 2007 | 08:17 AM
  #122
Mojo Rising's Avatar
The stock is not a 3 BAR, it is a 1 BAR. The JDM MAP is the 3 BAR sensor. The stock USDM sensor can only read vacuum up to about 2 PSIG, while the JDM can read up to just over 30 PSIG.
Old Oct 10, 2007 | 08:33 AM
  #123
trinydex's Avatar
Originally Posted by aalzuhair
I don’t know if you guys have any evos with 3bar map sensors and IAT stock .. mine is .. It came with an IAT sensor in the intake manifold and a 3bar map sensor.
i'm asking him
Old Oct 10, 2007 | 11:13 AM
  #124
aalzuhair's Avatar
No, the are the same ... But we don't call them JDM
Old Oct 10, 2007 | 11:17 AM
  #125
trinydex's Avatar
so all 9s? or just yours? how do you tell or did you get your car used from a savvy previous owner. sorry if i'm thoroughly confused as to how you managed to get the jdm and how many people out there might be replacing their sensors when they don't need to...
Old Oct 10, 2007 | 11:39 AM
  #126
mrfred's Avatar
All the USDM cars have 1 bar sensors. Its easy to verify by looking at the ROM code. Also easy to verify by logging data with it. The AU, NZ, and EDM cars do not have a MAP sensor.
Old Oct 10, 2007 | 02:59 PM
  #127
Tuner@Swift's Avatar
He lives in Saudi Arabia, so he has a JDM evo. Therefore, he doesn't need to replace the sensor.
Old Oct 10, 2007 | 03:32 PM
  #128
trinydex's Avatar
confusion aleviated
Old Oct 11, 2007 | 04:03 AM
  #129
aalzuhair's Avatar
I'm sorry trinydex, I should have said that I do live in Saudi Arabia and our cars are called as per the dealer "General Export cars" ... not MR or RS ... It comes with:
1) Blistin shocks
2) BBS wheels
3) NO recaro seats
4) Brembo brakes
5) 5sp
6) ABS
7) ACD
And then we have the GSR which comes with all of the above, plus
1) Recaro leather seats
2) AYC
3) 6sp
Old Oct 16, 2007 | 01:09 PM
  #130
JordanS4's Avatar
step by step guide PLEASE!
Old Oct 19, 2007 | 08:10 AM
  #131
evopower1021's Avatar
+1
Old Oct 19, 2007 | 09:04 AM
  #132
I wish it were so simple. Here's the abridged version:
1. Obtain and install JDM MAP sensor
2. Obtain GM IAT sensor.
3. Remove intake manifold and drill out a bung for the IAT sensor (right next to the MAP sensor) then reinstall IM
4. Install IAT sensor and wire in place of the stock IAT sensor from the MAF sensor
5. Use 1k Ohm resistor in place of BARO sensor
6. Copy all of your current maps into the patched ECU image
7. Spend 500 hrs fine tuning the VE and fuel tables
Old Oct 19, 2007 | 10:45 AM
  #133
mchuang's Avatar
The bold part is misleading I wish it were that easy but unfortunately its only available for the evo 9 as far as copy and paste. For my rom since I dont know how to patch it I have to wait until someone proficient can patch or unless Bez gives a step by step guide on patching the rom. Just ordered a rev hard manifold and a pte 6031re too dam
Old Oct 19, 2007 | 10:47 AM
  #134
mchuang's Avatar
Mixmastermatt have had a chance to get some dynoresults or anything. How does your car feel vs when you were on maf??
Old Oct 19, 2007 | 12:16 PM
  #135
Jeff_Jeske's Avatar
Lots of posts..... how many people are beta testing this?
