how-to: ECU-based direct boost control
Old Sep 28, 2008 | 05:57 PM
  #421
mchuang's Avatar
Originally Posted by Kings Fan
I need some help,
I recently got tuned with the this boost control, but when I pull my rom I see the tables like this. I'm using ecuflash 1.35. Can anyone help me out? Thanks
Did you update your evobase7.xml file and change the endian to big?
Old Sep 28, 2008 | 06:14 PM
  #422
mrfred's Avatar
I need some help,
Looks to me like there is something wrong with the scaling entries for ECUFlash. Did the tuner do psi-based boost control? If yes, who was it?
Old Sep 28, 2008 | 07:39 PM
  #423
RazorLab's Avatar
It was me, I sent him the XML so it should work for him now.
Old Sep 28, 2008 | 07:54 PM
  #424
Jack_of_Trades's Avatar
You have the BEC table zeroed out?
Yeah the BEC is zero'd out.
Originally Posted by tephra
Jamie - is this 94170015, apparently that might have a bug in regards to boost.. I need to check it out... :|
Yeah, the 94170015. PLEASE figure it out soon!! I'm going to the track for the last time for the entire season this friday and I need to break 11's or my head will explode,lol. The track is where I want the failsafe map switching the most!
Old Sep 28, 2008 | 08:11 PM
  #425
mrfred's Avatar
Should have guessed it would be someone I knew. :-) I think he may have duplicate xml files in the rommetadata folder.
Old Sep 29, 2008 | 09:32 PM
  #426
Kings Fan's Avatar
Well I checked it and I don't think that's it. I checked the scalings in ecuflash and I don't see one for "offsetwgdc" or "boosterrorpsi" like it states in the .xml file. Does this work for the 88590013 rom? When I load the rom in ecuflash it says it inherits from 88590013?
Attached Thumbnails how-to: ECU-based direct boost control-romid.jpg
Old Sep 29, 2008 | 09:36 PM
  #427
mrfred's Avatar
What ROM are you running?
Old Sep 29, 2008 | 09:55 PM
  #428
RazorLab's Avatar
You have a 88590015 rom
Old Sep 29, 2008 | 10:00 PM
  #429
Kings Fan's Avatar
When I first bought my car it was 13. But I think Bryan flashed it to 15??
Old Oct 2, 2008 | 05:21 PM
  #430
Evoryder's Avatar
Question Mfred. Is the address listed for my rom used for Direct boost control / load ?
Reason i ask is because when i use the direct vairable address you note I get only wastegate pressure. Yes I used the "0x" before entering it...
I was given the address "0x895c" thats what another member uses and he says it works fine with the 2byte load. Thanks
Old Oct 2, 2008 | 08:25 PM
  #431
mrfred's Avatar
What ROM are you using?
Old Oct 2, 2008 | 08:31 PM
  #432
Evoryder's Avatar
I figured it out. The 0x895C is for the Load based tuning, and the direct boost is the other one....i'm using ROm 94170015
Old Oct 3, 2008 | 04:40 AM
  #433
borjaland's Avatar
Hi to every body from spain!!
I´m trying to make the modifiation in a 96420008 rom, but the Boost Error correction and the Boost Adder maps , shows the psi values differents from the other roms on this thread.
On the next picture you can see all new boost control maps.
Can be an address problem???
Thanks and sorry for my poor english
Old Oct 3, 2008 | 05:13 AM
  #434
MR Turco's Avatar
Looks like your BEC is the only table off. Probably an address problem. Hopefully someone can help you out.
Old Oct 3, 2008 | 07:43 AM
  #435
mrfred's Avatar
If you are using a newer version of ECUFlash, did you change the endian value from "Little" to "Big" in the scaling definitions?
EDIT: I am seeing the same thing with my copy of 96420008. I'll post a fix in the first post today.
