how-to: ECU-based direct boost control
Old May 24, 2011 | 06:40 PM
  #976
killerpenguin21's Avatar
i was modding a rom to prepare for ecu boost, car is on an mbc currently. i opened the wgdc table and it was 100's full across, and im curious why...
although the rest of the tune was so ****ty im not surprised its effed up.
Old May 24, 2011 | 06:46 PM
  #977
Ian0611's Avatar
I don't think the WGDC makes a difference then with the MBC. If you were on ECU boost though you'd be overboosting like crazy I'm guessing.
Old May 24, 2011 | 07:01 PM
  #978
RazorLab's Avatar
Yes 100% is factory settings. The factory pill is sized for factory boost.
If you are running a 3 port or OEM bcs with a upgraded pill you will run much lower duty cycle.
Old May 24, 2011 | 07:14 PM
  #979
interesting.
i guess i have a lot more reading to do. dont most people run aftermarket bcs's without any pills?
Old May 24, 2011 | 07:32 PM
  #980
RazorLab's Avatar
interesting.
Yes 3-port BCS's are run with straight vac lines and no pills.
Old May 24, 2011 | 07:38 PM
  #981
deeman101's Avatar
You can run a pill with an aftermarket BCS but its a tradeoff between quick response and smoothness/controllablility. Generally the latter is not an issue.
Old Jun 19, 2011 | 01:10 AM
  #982
Eisen7's Avatar
I'm having trouble getting my boost to drop down to the level I want. I'm chasing about 23 psi, but even with the WGDC and BEC tables zero'd out, I'm still hitting and holding about 24psi. See attached pic of the WGCD table and a log showing the WGDC in action. Note that I've got the 100% wastegate duty load set to 150.
I'm running the mods in my sig. The turbo has a FP 18psi actuator. Have I got too much preload on the actuator, or is there another setting somewhere I should check?
how-to: ECU-based direct boost control-zerowgdc24psi.jpg
how-to: ECU-based direct boost control-zerowgdc.jpg
Old Jun 19, 2011 | 03:22 AM
  #983
burgers22's Avatar
What solenoid do you have? Have you tried running with just a pipe from the turbo outlet to the WG? You should get 18psi with that.
Old Jun 19, 2011 | 05:36 AM
  #984
Eisen7's Avatar
I'm running a Grimmspeed 3 port. Haven't tried connecting the turbo outlet hose directly to the WG yet.
Old Jun 19, 2011 | 06:40 AM
  #985
deeman101's Avatar
Check your boost adder. Whatever you put in the boost table it will be added to the boost adder, so 0psi on the table will not actually be the target.
Old Jun 19, 2011 | 10:38 AM
  #986
RazorLab's Avatar
That is incorrect, his BEC is zeroed out, and his log is showing 0 WGDC so obviously nothing is being added.
Boost adder and desired boost table will do nothing if BEC is zeroed out.
I'd imagine there is too much preload on the WGA
Old Jun 19, 2011 | 02:38 PM
  #987
deeman101's Avatar
Guess I didn't read his post carefully enough.
Old Jun 19, 2011 | 04:44 PM
  #988
Eisen7's Avatar
Thanks Razorlab. That's my hunch as well - just wanted to make sure I wasn't doing anything silly in the ECU settings before I took some preload off it.
Old Jun 20, 2011 | 09:36 AM
  #989
D-VO's Avatar
I though when it is when you have wgdc zero'd you get full boost. Meaning the wastegate is is not being used at all. Isn't that the way it works?
Old Jun 20, 2011 | 09:53 AM
  #990
RazorLab's Avatar
No, if you have WGDC tables zeroed out with BEC off, you would get wastegate pressure.
