2 Byte Load for 96420008 ?
Old Oct 5, 2007 | 01:21 PM
BoostEEd's Avatar
Does anyone know what the addresses are to be able to log 2 byte load on this ROM?
Old Oct 6, 2007 | 09:41 AM
elhalisf's Avatar
<table name="2 byte load high bit" category="Misc" address="39fa2" type="1D" level="1" scaling="uint16" />
<table name="2 byte load low bit" category="Misc" address="39fa6" type="1D" level="1" scaling="uint16" />
change to 35204 and 35205
Old Oct 6, 2007 | 06:51 PM
BoostEEd's Avatar
Cool thanks!
Old Nov 22, 2007 | 01:30 PM
Mr. Wright's Avatar
I tried useing this address, when I saved my .xml and then opened ecu flash, and there were no new maps under the misc section? Any hints.
Old Nov 22, 2007 | 01:33 PM
JohnBradley's Avatar
Do you have it set to developer mode? I also hate to have to ask this question but you did put it in the correct xml?
Old Nov 26, 2007 | 05:53 AM
BoostEEd's Avatar
I'll have to look tonight but I am pretty sure I ended up having to put it in the evo7base.xml file.
Old Nov 26, 2007 | 09:58 AM
Mr. Wright's Avatar
I saved the xml under the 96420008.xml in the ecuflash rom defination folders. So if this is the wrong place then yes I messed up, other wise it just isnt that difficult, although I am using vista which makes everything more difficult then needed.
Old Nov 26, 2007 | 11:32 AM
BoostEEd's Avatar
Thats why I say I put it in the evo7base.xml file. I did the same thing your describing and it didn't show up, but if you read that 9642008.xml file you'll see that it includes the evo7base.xml file. I can post up both of my copies of those files tonight when I get home.
Old Feb 3, 2008 | 09:06 AM
nj1266's Avatar
I want to bump this up. I entered the code that elhalsif posted and I got two tables:
2 byte load high bit---34999
2 byte load low bit----34998
Are the numbers 35204 and 35205 correct?
Old Feb 3, 2008 | 11:44 AM
FuelsResearch's Avatar
Yes they are.
Kaveeth
Jan 26, 2015 05:35 PM
iXac
Feb 10, 2012 07:05 AM
3gEclipseTurbo
Jun 2, 2011 07:58 PM
adcgn45
Jul 30, 2010 04:49 PM
racer135
Apr 17, 2008 06:36 AM
