How To Tune an Evo
Old Apr 7, 2008 | 11:03 PM
  #406
VegasVIII's Avatar
This is a great thread. I hate to be obvious, but I hear a lot of people wanting to eliminate there rear o2 sensor and wire in a full time wide band instead. Be aware your wide band must be in front of your catalytic converter, if you use a catalytic converter?
Old Apr 7, 2008 | 11:24 PM
  #407
tephra's Avatar
correct - just incase that was a question, as denoted by the ? at the end!
Old Apr 7, 2008 | 11:33 PM
  #408
JohnBradley's Avatar
Originally Posted by Jack_of_Trades
EFI 101 course is the only option I know of.
I will be offering a course in the future. It will be more ECUflash specific but tuning is tuning.
Tuning-
Its numbers and watching what the datalogger tells you is working and what isnt working. The "theory" that alot of tuners proclaim as gosepl tends to be (at least to me) opinion more than substantiated fact. Obviously there are always the things that work and things that don't, but the blending of the values in between is where some people get carried away.
Old Apr 8, 2008 | 04:44 PM
  #409
sba's Avatar
sba
Tuning-
Can you be more specific??? I am interested from some time like you know. Maybe...
Old Apr 8, 2008 | 10:27 PM
  #410
VegasVIII's Avatar
I took my converter off. I was just making a joke
Old Apr 9, 2008 | 01:32 PM
  #411
80210's Avatar
What's the best way to adjust MIVEC, I see the JDM IX RS map and used that as a beginning point but how should I tell what to change?
Old Apr 9, 2008 | 07:37 PM
  #412
nj1266's Avatar
If you have 272 cams, then use the JDM RS mivec map. It is an excellent map. If you do not have ca ms, then use my aggressive map. Do not use my aggressive map with cams because it is likely to trigger a p0300 code. Alao, do not advance you ignition timing at idle beyond 7*, because that is likely to trigger a p0300. If you have injectors that are not scaled, that might also trigger a p0300.
More than 32,000 views and 400 posts. Thanks for making this thread so popular
Old Apr 10, 2008 | 10:00 AM
  #413
80210's Avatar
Two caveats about this map: First, it will slightly increase your idle by about 100-200 rpm during normal driving. Second, after you hammer on the car for a while, your idle will go up to 1000 rpm. If you can tolerate this, then go ahead and use the map. If you cannot, then use the JDM 9 RS map.
Why does the idle increase after a while? Is the aggressive map too hard on the engine and will the idle ever decrease? I'm looking for a safe MIVEC map w/o cams.
Thanks!
Old Apr 10, 2008 | 11:52 PM
  #414
codgi's Avatar
Tuning-
I'd be interested in this so let me know when you get this setup.
Old Apr 15, 2008 | 06:36 PM
  #415
Paulnsx's Avatar
i'm sure this has been said MANY times before... awesome write up
Old Apr 20, 2008 | 06:42 AM
  #416
alloutDSM's Avatar
can i clear dtc's with ecuflash?
Old Apr 20, 2008 | 06:59 AM
  #417
Jack_of_Trades's Avatar
No, but Evoscan is supposed to have this feature but I don't think he has all f the bugs out of it just yet. Soon I hope.
Old Apr 20, 2008 | 07:04 AM
  #418
nothere's Avatar
good question, that may be a possibility in the future, currently Evoscan does, at least partly and depending on version. ECUplus certainly does.
I suggest the creder for trouble free clearing and reading. ~ $35 ebay. Plus you get a cable extension that moves the ecuflash cable out from under the dash.
Old Apr 20, 2008 | 10:58 AM
  #419
80210's Avatar
will you link me to it? I searched ebay but no luck finding it. Thanks!
Old Apr 20, 2008 | 11:08 AM
  #420
nothere's Avatar
would have helped if I had spelt it right
http://cgi.ebay.com/ebaymotors/Cread...spagenameZWDVW
