How To Tune an Evo
Old Feb 29, 2008 | 12:50 AM
  #391
nplatenkamp's Avatar
Talking
Originally Posted by Jack_of_Trades
Last thing than I'm going to bed,lol.
For the most precise adjustments from 7.38 AFR to 14.7 AFR:
Change "Edit Increment" to 0.0575
Change "Format" to %.2f (so you can see the number change every time you go up or down one increment)
For the most precise adjustments from 7.38 AFR to 16.08 AFR (for you fuel economy tweakers):
Change "Edit Increment" to 0.0685
These give you the most adjustments possible in our usable range in the Fuel Map cells.
You can try to enter more precision "AFR" values but you would also need then a O2 sensor which is capable to measure accurately on at least 2 decimals (like 11.95).
Which most O2's can not do. So it has not much use putting a value like 12.65, because you can not measure the result on 2 decimals. You get for example 12.6 from the O2 sensor which has a span of 12.5 -12.7.
  #392
80210's Avatar
Is there a way to copy and past an entire section of cells onto a new one? Without going through each individual cell?
Old Feb 29, 2008 | 12:56 AM
  #393
80210's Avatar
Also anyone interested in adding an idle section to this? Could be a good add-on. Thanks!
Old Feb 29, 2008 | 04:02 AM
  #394
Jack_of_Trades's Avatar
Hi, please keep in mind that the O2 sensor is mostly only accurate to 1 decimal place. So 12.3 can be 12.2 or 12.4, so it makes no sense showing 2 decimals
really.
Will you STOP saying this! This is an OPEN LOOP fuel map! These settings have NOTHING to do with the O2 sensors output man. Jeeze.
Old Feb 29, 2008 | 04:03 AM
  #395
If you left-click and hold with your mouse you can drag over multiple cells to highlight them. Then you can copy and paste large areas.
Old Feb 29, 2008 | 06:15 AM
  #396
scc_tuner's Avatar
you guys do realize that afr's are just thermal management and that getting into the decimals of an afr wont affect horspower or torque. If you take your map cel from 13.1 to 13.0 you are probably not going to see a difference in hp or tq numbers, so why go so deep into the decimals of the afrs if they really don't make that much of a difference.......unless it'S JUST BECAUSE YOU CAN!!!!
Old Feb 29, 2008 | 06:25 AM
  #397
Jdsevo88's Avatar
nice write up man..
Old Feb 29, 2008 | 09:12 AM
  #398
It never hurts to have MORE control over things than you need to use I'd rather have smaller incremental changes from cell-to-cell during a pull than larger jumps. There is nothing wrong with a quest for perfection,lol. It had more to do with the fact that a question was posed on how the incremental changes were a little funky, then we just wanted to get into the specific DETAILS of how the adjustments were working for us and how we could manipulate them. THough it may not be necessary, simply changing your "edit Increment" value from .1 to .0575 adds 42% more adjustability between the 7.38 and 14.7 cells. This would useful for someone who wants to try and tune as CLOSE to their knock edge as possible I guess.
Yeah..basically cuz we can I guess,lol.
Old Mar 4, 2008 | 02:09 PM
  #399
Imports14life's Avatar
Subscribed! Thanks for the great write up. All that information went WAY over my head, but i will keep reading it untill i understand it. Great that people share their talents and love of cars with the rest of us. Keep up the good work! :-)
Old Mar 16, 2008 | 08:49 PM
  #400
bk.adams's Avatar
Great info in here !!! I'll have to re-read it SEVERAL times, but I think I'll give this
tuning a try.
Brian
Old Apr 4, 2008 | 04:40 PM
  #401
Gary@MellonRacing's Avatar
how to tune
i was just wondering is there a school u can go to learn how to tune??
Old Apr 4, 2008 | 05:53 PM
  #402
EFI 101 course is the only option I know of.
Old Apr 4, 2008 | 06:21 PM
  #403
C6C6CH3vo's Avatar
Just do a lot of reading (books, papers, abstracts, magazines, **** - JK), logging, flashing, dynoing; spending of a lot of money, time in the garage while pissing off your wife, and developing a dependence to non-domestic beer.
This is what it takes to become an arm-chair tuner - being part of the abyss as myself.
Old Apr 4, 2008 | 06:48 PM
  #404
Yeah, I've been down this path all too often,lol. I've got my Masters Degree in this area.
Old Apr 6, 2008 | 06:46 PM
  #405
tephra's Avatar
+1
