How To Tune an Evo
Old Aug 19, 2008 | 07:11 AM
  #511
92gsxbaltimore's Avatar
so you are running 440cc injectors and you have set the injector scaling value to 740cc?
Old Aug 19, 2008 | 08:06 AM
  #512
Chabada15's Avatar
well its obviously not fine if your running lean
Old Aug 19, 2008 | 07:03 PM
  #513
nestoledo's Avatar
it installs them, and already it sounds well. but an injector has flight, tomorrow change the o rings and to prove it
I have another question, why when I re scale the values of the load, also the values change of injector battery latency?
i can not upload the rom file
Old Aug 20, 2008 | 08:36 PM
  #514
Pro-Spec's Avatar
Great info, very helpful.thanks
Old Aug 21, 2008 | 06:30 AM
  #515
nestoledo's Avatar
not definitively my Ecu is not for handling extreme values, I am thinking seriously about changing to EMS
i rescale injectors an make new maps, but the result is the same
i can not do that the injectors open to full capacity
Old Aug 21, 2008 | 10:52 AM
  #516
Chabada15's Avatar
if the injectors are at 100% duty cycle then you need bigger injectors...yanno if you could log your car and post up then we might be able to help you better
Old Aug 21, 2008 | 12:26 PM
  #517
nestoledo's Avatar
how I can obtain log of my car
i have evoscan, but i do not know how obtain it
Old Aug 21, 2008 | 12:48 PM
  #518
mrfred's Avatar
Do you have a Tactrix cable?
Old Aug 21, 2008 | 12:59 PM
  #519
Chabada15's Avatar
he does have one cause hes obviously tuning it but evoscan may not be suitable for the regular lancer
Old Aug 21, 2008 | 01:07 PM
  #520
nestoledo's Avatar
Ok, then how obtain the log of my lancer ES 2003
Old Aug 21, 2008 | 01:16 PM
  #521
Chabada15's Avatar
no idea
Old Aug 21, 2008 | 01:34 PM
  #522
nestoledo's Avatar
ok, I will to try with evoscan and will see that it happens
thank you
Old Aug 22, 2008 | 10:55 AM
  #523
evo8kid-VIP's Avatar
so nj i have a 2004 evo8 i have utec installed its just had to get set up right .....so can i reflash with utec in??????? we r new to all this evo tunning ...so i just go to openecu and download the program for free????
Old Aug 22, 2008 | 11:18 AM
  #524
TouringBubble's Avatar
EvoScan does work on the 03 Lancer.
Old Aug 22, 2008 | 11:27 AM
  #525
Chabada15's Avatar
a UTEC is a piggy back programmable system, you would use the UTEC software to tune the utec, not ecuflash, you can remove and sell the utec and then use ecuflash on your stock ECU and accomplish the same thing
